Anyone get Lexus to order the hitch kit?
#46
Even if you're never going to tow anything. The towing prep option is worth every. You get a larger radiator, better cooling system, transmission and oil cooler. It is not very expensive, and adds extra protection for your car.
#47
1) PT228-48160 ($550 MSRP) - hitch itself
2) 52108-0E060 ($176.57 MSRP) - bumper trim extension (the RX350 may have a different number, because the bumper trim around the tailpipes are different than the 450h) that goes around the hitch opening.
3) Labor was quoted 3 hours ($165/hour)
#49
On the RX450h, the OEM hitch install order contains two parts plus labor:
#50
Finally got my OEM factory tow hitch installed by the dealer on the RX450h.
What you see here are exactly PT228-48160 (hitch) & 52108-0E060 (bumper trim). Therefore no trimming or cutting around the hitch opening on the bumper. The dealership did have to trim the plastic shroud under the car, as that's what the hitch instructions call for. Also note the 4-pin connector on the hitch itself.
To install the hitch, the rear bumper cover, foam absorber, and metal beam have to be removed. The metal beam inside the bumper is actually replaced by the new hitch, which itself is now part of a new metal beam.
Also note the differences in the bumper trim piece between the hybrid and gas (in RXOwner's previous posts) RX's.
Total cost, after applying multiple coupons and sales, came out to be about $920 (parts and labor).
#52
I just ordered the Curt hitch (C13272). I probably won't have it for a week or so. I have always gone aftermarket. This is my fourth RX. I can post pics, when I install it, if anyone is interested.
#54
2016 RX450h with factory hitch installed
We ordered our 2016 RX450h with factory hitch. Had to come back to have hitch installed, and cost was $1300!!! One disappointing thing is it comes with a 4 pin electrical connection and we need a 7 pin connection.
Lexus dealer was NOT helpful and said that they would only do a 4 pin connection. Shopping around for a converter and someone to install.
Think that we will not have the 7 pin installed (drill holes in bumper for install) but just have jumper cable with temporary connection.
#55
Lexus Tow Hitch for F Sport
#56
#57
Took a look under the rear bumper and noticed that their appears to be
pre-drilled holes ready to accept a hitch. The only concern I have is
having to deal with the rear bumper fascia and whether or not it needs to
be cut a little to allow the hitch to sit a little higher in the frame, so as not
to be too visual when viewing the RX from the rear. I believe that is how
some previous model hitches were installed.
#58
$9.25 adapter http://factorylexusparts.com/towing-...4-pin-adapter/
#59
What year is your RX? Our new 2016 450h plastic trim around the hitch looks different than yours. The dealer installed ours and the cut out for the hitch is not centered on the hitch. Dealer says that it comes from the factory that way......I am not buying it. Looks shoddy. Will post pictures after I get home and take a couple.
#60
Disappointing quality control from a brand that likes to beat its chest about quality control, but all is good now.
