Regular or Premium Gasoline Required?
#181
I cant believe this has gone on for 12 pages.
Its pretty simple, 87 is fine, 91 is fine, use whatever you feel appropriate. Timing will be adjusted accordingly.
I fill 87 because im a cheap *** and this car isnt worth the extra $$. My sc430 on the other hand will knock if you put anything lower than 91.
#182
The definitive word from Lexus: Which fuel grade should I use for my Lexus vehicle? (https://support.lexus.com/s/article/...rade-shou-8129.)
I'm sure this will end the discussion, and this thread will never see another post.
jollick (03-07-24)
#183
This thread is more nostalgic than my best old sweatshirt!
Here's the definitive rule for fueling your Gen. 4 RX, and I quote the former service manager of Lexus Dayton:
"It runs on regular. It runs better on premium."
NOW, we can be done.
The following 7 users liked this post by dibl:
ashilcoski (07-20-24),
autotech13 (03-08-24),
bamalam (03-07-24),
coolbrazz (03-08-24),
jcg0324 (03-08-24),
and 2 others liked this post.
#184
#185
Just follow the darn owners manual! How much longer does this need to be discussed?
The following 3 users liked this post by autotech13:
#186
You had me at: "Recommended Minimum"
The following 2 users liked this post by toyotaman7:
autotech13 (03-09-24),
coolbrazz (03-09-24)
#188
autotech13 (03-10-24)
#189
Got this from my user manual (RX MY2017)
Engine
Model 3.5 L 6-cylinder (2GR-FKS)
Type 6-cylinder V type, 4-cycle, gasoline
Bore and stroke 3.70 3.27 in. (94.0 83.0 mm)
Displacement 210.9 cu. in. (3456 cm3)
Valve clearance (engine cold) Automatic adjustment
Drive belt tension Automatic adjustment
Fuel
Fuel type Unleaded gasoline only
Octane Rating 87 (Research Octane Number 91) or higher
Fuel tank capacity (Reference) 19.2 gal. (72.5 L, 15.9 Imp. gal.)
Engine
Fuel
The following 3 users liked this post by exonw:
#191
Engine
Fuel
Engine
Fuel
ravenuer (03-29-24)
#192
lock this thread!
