TPMS Replacements
Old Nov 21, 2022 | 07:50 AM
ravenuer's Avatar
ravenuer
Originally Posted by PeeVee
That happened to me at first for my winter tires when I just had bought mine, and what they realized is that the parts guy gave them a 3Gen TMPS, when they switched to the proper one it worked, But of course they had lost time to remove the tires and re-balance the wheels because of the parts guy mistake.
That at least makes sense.
Old Nov 21, 2022 | 07:53 AM
PeeVee's Avatar
PeeVee
For people reading this page and don't know this, 4th Gen RX is using 433 MHz TPMS while the prior generations where using 315 MHz TPMS.
Those are the two standards used throughout the industry for the majority of brands. So any generic TMPS at 433 MHz will do! No need to be Toyota nor Lexus.
Old Nov 21, 2022 | 09:24 AM
lexo98's Avatar
lexo98
Originally Posted by fossil
I bought a nice set of aftermarket wheels for my RX350. I purchased Lexus TPMS sensors upon recommendation from my mechanic to insure they would perform correctly. Ironically, they didn't work. No one, including Lexus, could program them. Lexus gave up and refunded me. I haven't decided whether to try another brand or give Lexus another chance. It's beyond discouraging that Lexus could not make their own brand of TPMS sensors work.
The ECU goes into a lock down mode if it thinks the TPMS is being messed with. It took a while for us to get info on how to get it out of the lock mode. Not everyone understands what needs to be done.
Old Nov 21, 2022 | 04:18 PM
lenbabin's Avatar
lenbabin
Lexo 98
Wow! How do you spell u n e x p e c t e d?
Old Nov 26, 2022 | 12:58 PM
Dap04's Avatar
Dap04
6th Gear
The sensors are good for about 10 years. I replaced the sensors on my 05’ tundra two years ago when the low tire pressures light would not turn off. Costco sells the sensors for for a bit less ,but not much $300. The tire tech at Costco gave me the info and I later researched it and all was true..
Old Dec 1, 2022 | 10:13 AM
lenbabin's Avatar
lenbabin
Yesterday, I had these installed in my winter tires:
Amazon Amazon
(Schrader 33500 EZ-Sensor) by the local Kaltire tire shop. The process went very smoothly (took me on time, process took an hour as indicated, wheel nuts torqued on the way out, tires were not dismounted so no balancing required). The first thing I noticed was that the tire pressure indicator was gone on startup. I called up the tire pressure info screen and it was blank all around. I drove about 5 km (3 miles) and suddenly all the values popped right up. So far, so good. Cost was $318 CAD ($235 USD). Happy.
Len
Old Dec 1, 2022 | 10:41 AM
ravenuer's Avatar
ravenuer
Originally Posted by lenbabin
Yesterday, I had these installed in my winter tires: https://www.amazon.ca/Schrader-33500.../dp/B00TPVZNUW (Schrader 33500 EZ-Sensor) by the local Kaltire tire shop. The process went very smoothly (took me on time, process took an hour as indicated, wheel nuts torqued on the way out, tires were not dismounted so no balancing required). The first thing I noticed was that the tire pressure indicator was gone on startup. I called up the tire pressure info screen and it was blank all around. I drove about 5 km (3 miles) and suddenly all the values popped right up. So far, so good. Cost was $318 CAD ($235 USD). Happy.
Len
Sounds like you're good to go!
Old Dec 1, 2022 | 06:27 PM
jcg0324's Avatar
jcg0324
Len
"tires were not dismounted so no balancing required" How do you install new sensors without dismounting the tires? Just curious.
Old Dec 1, 2022 | 09:07 PM
lexo98's Avatar
lexo98
Break the top head and install the sensor. The. Reinflate. The price of install should include a rebalance though
Old Dec 5, 2023 | 03:54 PM
Rainor's Avatar
Rainor
9th Gear
Default TPMS on 2019 Rx350
I have aftermarket wheels on my RX with aftermarket TPMS valves. Lexus tell me they can't program the TPMS to my car and that I must buy Lexus ones for $500+. Is this true?
Thx for any help.
Old Dec 5, 2023 | 03:58 PM
ravenuer's Avatar
ravenuer
Thx for any help.
You should ask the guy who installed the TPMS sensors in your wheels.
Old Dec 5, 2023 | 04:04 PM
Rainor's Avatar
Rainor
9th Gear
Thx but I bought the wheels second hand so I have no idea.
Old Dec 6, 2023 | 05:50 AM
toyotaman7's Avatar
toyotaman7
at minimum you need to know what vehicle they were used on before. Then you can back track to see if they might work.
Old Dec 7, 2023 | 03:44 AM
jcg0324's Avatar
jcg0324
Here is a decent website that gives part numbers for different tire pressure sensors from various sources. Might help somebody out:
https://www.tpms.com/Lexus-TPMS-s/1851.htm
Old Dec 10, 2023 | 05:22 PM
LexusORD's Avatar
LexusORD
10th Gear
Great link, thank you for that info. I also found a site that's a Lexus Dealer that has a pretty good price on TPMS sensors. They're in Akron, OH. www.lexusoeparts.com
I myself am in the shopping phase for a 2021 or 2022 RX350 F-Sport, and hopefully we will be owners soon. I am proactively looking into wheels for winter tires and seem to find several different part numbers for Lexus TPMS sensors. 42607-48010, 42607-53020, 42607-06090 are the three numbers I see. I guess I will have to read the sensor part number on the vehicle we purchase in order to know which one to get?
