Passenger Door Sometimes Won’t Lock Or Unlock
Old Jul 11, 2022 | 10:44 AM
gadgetman1's Avatar
gadgetman1
Default Passenger Door Sometimes Won’t Lock Or Unlock
My 2016 RX 450h has 42,000 miles & sometimes (more often than not) the passenger door won’t lock and/or unlock. The only way to lock the car is to push the door plunger down. To unlock it, I have to lean across the seat & pull on the door handle. Neither the remote or touching the outside handle will lock/unlock. There is clicking inside the door & the audible beep sounds, but nothing happens. Has anyone had this issue?
Old Jul 11, 2022 | 11:54 AM
Cocal's Avatar
Cocal
Is the battery still the original?
If so it may be the cause, in these vehicles full of electronics a low voltage battery can create all kinds of problems and send all kinds of codes.
Check battery voltage and if still the orig one try a new one just to see, if you can.
Old Jul 11, 2022 | 12:58 PM
gadgetman1's Avatar
gadgetman1
Yes, it is original. I never gave the battery being the cause a thought! I’ve never seen my battery - I just know it’s buried under the cargo floor.
Old Jul 11, 2022 | 01:20 PM
Cocal's Avatar
Cocal
I missed that yours is a hybrid, but the possibility still holds, have the electrical system checked.
Old Jul 11, 2022 | 01:28 PM
coolbrazz's Avatar
coolbrazz
Hopefully it's just a battery, but could be the dooractuator. I've read on a string here before about a similar issue and this was replaced.
DudleyTL
Jan 3, 2019 08:32 PM
LexLuger31
Jul 2, 2011 11:27 AM
MATEOGS
May 30, 2008 06:18 PM
