Where to buy OEM brake fluid please
Thug9030, it sounds like you are trying something for the 1st time. Flushing a break hydraulic system by yourself is not that simple or easy. Please refer to online youtube videos that show how to do do it. It is always better to have a friend help you with an operation like this.
thug9030 (01-15-22)
I really appreciate info and tools suggested and I’ll make sure to watch tons and tons of videos and read until I’m 100 percent confident on doing this for my vehicle. Yea it’s easier to go to the dealer and pay and get this done but the satisfaction will be great for now and future vehicles I’ll own . Before you know it I’ll be rebuilding cars hahaha sike .
hello wondering if someone can recommend me a site that sells oem brake fluid if its such a thing. i just would like to continue to use the same fluid thats lexus puts in and how many gallons or ounces should i use after draining my brake fluid. I have a 2018 rx350 f sport awd
thank you
thank you
Skip to 8 minutes and 45 seconds for the brake fluid part.
How do you know your brake fluid needs to be replaced? The cost of new brake fluid is minimal if you do it yourself but it is a pain in the ***. Watch this video and be more informed.
https://www.youtube.com/watch?v=G5xFLj5baJw
You obviously did not watch the video otherwise you would not have made such a rediculous remark about changing oil. Changing oil and brake fluid are two different maintenance requirements. Brake fluid is not exposed to the high heat, acid and carbon chemicals and pressures of engine oil. Please watch the video.
Brake fluid is hygroscopic though—it absorbs moisture from the air. And it is exposed to high heat, at the calipers. Decades ago I never would’ve bothered with flushing brake fluid, but in the last twenty years or so I have seen ABS systems go haywire from a little bit of internal corrosion. So I don’t flush it religiously (not as often as the manual) but I do try to flush it at some point in the cars life before it’s first brake change.
For those that don't want to watch the video he says replace brake fluid every 3 years I about follow this schedule. He also says don't judge brake fluid by the colour test the moisture content instead. Technically that's correct, but after 3 years I can plainly see brake fluid is much darker and needs to be flushed out. According to him high end brake fluid can be much darker in colour I've never used such fluid.
Go pull the cap off the reservoir of a vehicle with 30,000 miles that has never had its brake fluid changed and siphon some fluid out of it, and compare it to new fluid. There will be a night and day difference in the color.
Y’all can go by the video if you want. I’m not. I am not going to claim to know more than people who do brake work for a living, but my experience and training is far more than most people. I’ve probably flushed brakes 100 times, and changed engine oil in high performance cars, motorcycles, and boats several hundred times.
