gas Cap holder?
Old Mar 20, 2019 | 01:26 PM
eddie420's Avatar
eddie420
Originally Posted by JSracer
what ?? you guys can'tt pump gas ??
car, motorcycle, anything ??
why ?? lol
Originally Posted by mikemu30
NJ is one of two or three states that do not allow self serve.
Not going to lie, I am spoiled. I love getting my gas filled, especially during cold winter mornings.
Old Mar 23, 2019 | 05:12 AM
PWMDMD's Avatar
PWMDMD
Originally Posted by kmiller882
I also have no issue putting the cap in the holder. Works just fine for me.
Yup...it couldn’t be easier IMO. Well it could be - the Pilot doesn’t have a cap which is even easier but if you have a cap the RX is as easy as it comes.
Old Mar 25, 2021 | 06:36 PM
Badhobz's Avatar
Badhobz
Default Where am I suppose to put the gas cap ?
Where am I suppose to put the gas cap !?! There is this small circular hole but my gas cap as nothing that would fit inside it.
Old Mar 25, 2021 | 07:45 PM
bamalam's Avatar
bamalam
It's not a perfect fit, but the nozzle end of the gas cap fits in the partial circular groove that's on the door. See the markup.
Old Mar 25, 2021 | 10:04 PM
Badhobz's Avatar
Badhobz
Thanks !
this is the weirdest design for a fuel cap holder I’ve ever seen.
Old Mar 25, 2021 | 11:57 PM
dannnn's Avatar
dannnn
i hang mine here, on the gas cap itself there is two notches that are there that "hook: or slide into there. This way the white plastic threads dont touch anything. If the white threads get dirty, over time it can cause a evap leak and make the tolerance loose causing an improper seal. Idk thats where i hang mine lol or when im lazy i just let it hang there.
Old Mar 26, 2021 | 04:51 AM
Cocal's Avatar
Cocal
This gas cap holder is the cheapest and most stupid design of any I've ever seen!
Old Mar 26, 2021 | 05:10 AM
Freds430's Avatar
Freds430
Old Mar 28, 2021 | 11:10 AM
SoCalRX's Avatar
SoCalRX
Thumbs up
I completely agree! I simply let the gas cap hang off its cord. Why place atop a holder that can introduce dirt and debris into your fuel tank because the holder itself gets dirty?
Old Apr 6, 2021 | 12:48 AM
dannnn's Avatar
dannnn
Well finally had to get gas and thats how i hang it
Old Apr 7, 2021 | 10:46 PM
HungGBA's Avatar
HungGBA
great idea, I tried and work for me. tks
Old Apr 8, 2021 | 04:52 AM
Bigjer2's Avatar
Bigjer2
Originally Posted by Freds430
FINNALY!!! Someone who read the Owners Manual!!!!
Old Apr 8, 2021 | 08:55 AM
TechNut's Avatar
TechNut
Veteran: Navy
I recently purchased this generation of RX and must agree with those that are perplexed by this strange design. However, it does seem to work OK even if it is a bit unusual. I also understand those that are concerned about dirt in the holder potentially contaminating the gas cap and ultimately getting into the fuel supply, however that same argument could be made against just about every gas cap holder I have ever used, regardless of model or generation. I'm not sure there is a perfect and completely sterile design for holding the cap during refueling but this design doesn't seem particularly worse than any other in my humble opinion. I am intrigued by the workaround option shared on this thread and will give it a try, although I am not particularly concerned with the factory option.
Old Apr 10, 2021 | 08:36 PM
ellocovg's Avatar
ellocovg
So me being from Jersey I’ve never had to worry about the gas cap. I’m on a road trip and has to gas up in Maryland and tried using the cap holder like two seconds before I said f this and just let it hang. Not sure how that thing would actually work. I see in theory how it would work, but the hanger is so stiff that it pulls it off the hook right away.
Old Apr 11, 2021 | 02:39 AM
dibl's Avatar
dibl
Both methods (#23 and #25) work perfectly on my RX. I had previously just let it hang, but the side hanger (#25) is appealing because the inner (white) surface is not exposed to any contamination.
