Cargo Cover Falling Apart
Old 08-20-18, 11:39 AM
gadgetman1
gadgetman1's Avatar
Default Cargo Cover Falling Apart
My cargo cover is falling apart! I have attached pics. Has anyone had this happen & how was it resolved?
The cover catches (when extended) are getting chewed up with normal use. Also, there are two felt covered guides that are screwed onto the cover frame. My screws have fallen out & gotten lost, so I’m down to 2 out of 4 screws. This appears to be junk. Why not rivot these guides?
SoCalRX (08-24-18)
Old 08-20-18, 01:57 PM
ericsan13
ericsan13's Avatar
The screws fell out on mine multiple times and I had it replaced under warranty.
In your first picture, it looks like someone tried to flip the back half of the cover around. Same thing happened with me too...bad passengers.
Old 08-20-18, 02:00 PM
gadgetman1
gadgetman1's Avatar
Hardly anyone has ever sat back there. That’s just from using it to cover my cargo once a week that I carry. It’s a pretty cheesy hook system.
Old 08-20-18, 02:41 PM
sderman
sderman's Avatar
Agree. When I changed from my '07 RX to my '17 RX I was appalled how degraded and flimsy this entire assembly had gotten. I am sure it was to save costs and weight.
Old 08-20-18, 04:09 PM
ericsan13
ericsan13's Avatar
At one point in time someone must've tried to flip your cover. That's the only way I can see that level of damage. Mine was perfect for two years until someone tried to flip it.
Old 08-20-18, 06:36 PM
mikemu30
mikemu30's Avatar
Received 2,368 Likes on 1,702 Posts
My cover is in the basement as I have no need for it and found it was more in the way of things than anything else.
Old 08-21-18, 06:27 AM
JSracer
JSracer's Avatar
flip it? What is that meaning? Sorry I don't understand, and trying to ensure I don't damage mine. Thanks
Old 08-21-18, 06:44 AM
gadgetman1
gadgetman1's Avatar
Im with you - I have no idea about “flip it”...we pull it closed to cover the cargo or take it out to place something big inside. Both sides of the plastic trim look like a bear chewed on them, including the rubber tips on the cover. I’ve seen better parts on a Yugo!
Old 08-21-18, 06:50 AM
mikemu30
mikemu30's Avatar
Maybe he means it was removed and reinstalled the wrong direction?
Old 08-21-18, 06:59 AM
gadgetman1
gadgetman1's Avatar
That’s possible, however there is nothing on the cover that indicates what end is UP. This is just a cheap, crap part.
Old 08-21-18, 07:07 AM
gregjhonda
gregjhonda's Avatar
My solution was too store the cover in my garage. It was always in the way anyhow.
Old 08-21-18, 07:35 AM
gadgetman1
gadgetman1's Avatar
You can’t cover your cargo & belongings when the cover is sitting in your garage. We use ours for what it was intended.
Old 08-21-18, 09:41 AM
mikemu30
mikemu30's Avatar
Precisely - I have no need to cover anything back there. If someone wants to vandalize your car, do you think the cover will deter them? Quite contrary, it is likely to attract sinister acts.
Old 08-21-18, 09:42 AM
mikemu30
mikemu30's Avatar
You're hating Lexus again
denverrob (08-23-18)
Old 08-21-18, 12:55 PM
ericsan13
ericsan13's Avatar
This is what I mean and what happens when your passengers mess with the cover. Can't blame them because it really should've been designed to do this anyway.
Pretend it is attached and someone flips it like this
Then you get a damaged cargo cover and damaged trim. You can't tell since it's dark but it's not pretty.
Quick Reply: Cargo Cover Falling Apart
