how do you replace cabin air filter??
Old Jun 2, 2017 | 07:58 AM
HenryNYC's Avatar
HenryNYC
Originally Posted by ericsan13
I would say that it's more an issue of design or "nickel-and-dime"-ing. Why make previously compatible parts incompatible so you can squeeze out $10 for a brand known for ease of maintenance?
That was actually my point and not that I'm being cheap. Like I said. The CF10285 filter is actually the size of the filter the 2016+RX uses except the pleats of the filter are flipped. Because of this, you can't use this filter which cost 15 bucks and easy to get but now have to buy one for twice the price and not so easy to find.
Old Jun 2, 2017 | 02:21 PM
aznkorboi's Avatar
aznkorboi
whoa whoa whoa. I put the 10285 filter side by side and on top of the current 2016 filter and the 10285 filter is too short compared to the rx filter in there.
Old Jun 5, 2017 | 09:46 AM
HenryNYC's Avatar
HenryNYC
When I get a chance. I'll pull the 10285 filter I purchased and compare it to the OEM filter. May not be till the weekend when I can do this. Will post pics when I get this comparison done.
Old Jun 5, 2017 | 10:00 AM
aznkorboi's Avatar
aznkorboi
sounds good! Thanks!
Old Jul 20, 2017 | 12:04 PM
Brabusx2's Avatar
Brabusx2
Default how do you replace cabin air filter??
don't see any DIY up yet, but i can tell its inside the glovebox as most lexus, i could drop the glovebox and unhook the hinges with piler,
but then i yank the plastic cover off and now there is this big hard plastic box enclosed case i don't know how to open it, any idea???
Old Jul 20, 2017 | 12:22 PM
TeKKieNYC's Avatar
TeKKieNYC
See page 600 in the owners manual.
Remove the Cover, then pull the filter case.
Old Jul 20, 2017 | 12:25 PM
FastFord's Avatar
FastFord
There is a little clip that locks the cover into place. Unlock the filter cover on the right side...might need a flashlight if it's dark. Then swing the cover out on the right side swinging it out, then it pulls out on the left side, where there are little claw like hinges holding it on. Sounds more complicated than it is, but that's basically what to do....
Old Jul 20, 2017 | 03:29 PM
Freds430's Avatar
Freds430
Make sure the A/C is on the recirculating mode before pulling the filter out.
Old Nov 12, 2018 | 06:22 AM
BensonTT's Avatar
BensonTT
Hey guys how do you pop out the glove department first to access it?
Old Nov 12, 2018 | 08:36 AM
JSracer's Avatar
JSracer
right side, you'll see an arm connected, when the door is open, that is the stop. carefully remove that from the door, and it will open down giving you access to the door behind it.
so open the glove box from the passenger side with the car door open, and you will see it.
Old Nov 12, 2018 | 09:23 AM
aznkorboi's Avatar
aznkorboi
open the glove compartment
empty out contents
squeeze both sides to release the 2 hinges that just attach to the sides
there is another small lever type device on the right that is holding the glove box
use some force and pull directly away from the glove box and it will release
then the glove box can be removed to replace the cabin air filter
Old Nov 12, 2018 | 09:45 AM
BensonTT's Avatar
BensonTT
Ok! Thanks a lot guys, I will try it this weekend when I get a new filter
Old Nov 12, 2018 | 05:36 PM
ravenuer's Avatar
ravenuer
May I ask why? I've replaced many cabin filters without being in recirc. Never had a problem.
Old Nov 12, 2018 | 08:26 PM
richard203's Avatar
richard203
why not just turn ur car off before changing the filter? o.0
Old Nov 13, 2018 | 07:23 AM
ravenuer's Avatar
ravenuer
Agree. I see no reason to have it running anyway.
