Squeaky wipers
Old Feb 25, 2019 | 09:00 PM
  #61
macdee's Avatar
macdee
Originally Posted by ravenuer
But the problem is gone, right?
Would have to wait for another rainy day to be absolutely sure, but just by splashing water on the windshield, the issues seems to be fixed.
For some reason, it always takes a proper rain to be really sure. But Lexus tech tested it, and I tested it myself, so I'd say yes it's gone. For now ¯\_(ツ)_/¯
Old Jul 17, 2019 | 07:19 AM
  #62
johnhey's Avatar
johnhey
Question Wiper blade noise
I have 2019 RX, when it rains my viper blade make noises while working. I think it is the small one (driver side).
it starts to make noise after a while like few minutes. the blade rubber looks fine. took it to dealer they said could not see the problem.
Do you have this issue or your blades operate quietly?
I have to turn up the music to mask the noise
Old Jul 17, 2019 | 08:58 AM
  #63
ravenuer's Avatar
ravenuer
1) Make sure your windshield is clean.
2) Replace both wiper blades.
Old Jul 17, 2019 | 09:19 AM
  #64
johnhey's Avatar
johnhey
"Replace both wiper blades."
I do not think it is normal to replace a blade on a new car just after 6 months.
Old Jul 17, 2019 | 09:33 AM
  #65
ravenuer's Avatar
ravenuer
No, it is not, but if the rubber blade has degraded for some reason and it squeaks or whatever, that is the only solution. Perhaps your dealer would replace them for you as good will.
If he won't cover the cost and you aren't able to change them yourself, go to any local auto supply store and ask if you purchase new blades, would they have someone install them for you? Almost all of them(AutoZone, Advance Auto Supply etc)will do that.
Old Oct 5, 2019 | 11:48 AM
  #66
Onion's Avatar
Onion
Has anyone experience striking when wiping? Mine only makes noise for the first few swipes, but it strikes crazy, it leaves bunch of thick water lines on the windshield, one of them right in the eye of sight. Brought it in for checks and they found another 2016RX to test with, same result but thinner lines.
They said there is a lot of play in the wiper blade and replaced it - 55 dollars. Not sure if it would fix anything to be honest.
To add on, it seems like washer fluids create less strikes compared to actual rain, in fact, during rain storms if I spray windshield fluid on the windshield the striking would be a lot less for around 20 seconds, before it comes back again.
And of course as always, they claim it to be normal functionality, yay, free water lines on the windshield for no extra charge.
Old Oct 5, 2019 | 11:55 AM
  #67
ravenuer's Avatar
ravenuer
Assume you mean streaking. That's usually caused by either worn blades or something on the glass. You said the dealer replaced your blades, so did that fix the problem? If it didn't then you need to thoroughly clean the windshield.
Old Oct 5, 2019 | 12:14 PM
  #68
Onion's Avatar
Onion
Sorry I typed on the phone and auto correct seems to like striking more
I will have to wait for an actual rain to test, but it seems to be better than before.
Old Nov 19, 2020 | 08:08 AM
  #69
NCRX350's Avatar
NCRX350
So is there an "official" fix for this now? I have this issue on my 2017. At first I got the usual dealer "we do not hear any problem", then went on a ride with them in the rain and got "Lexus is aware of this issues and there is no current solution".
I see some of the options are a windshield coating and new wipers, and I see a new wiper arm replacement. Would love to have something to go back to Lexus with.
Old Nov 19, 2020 | 09:56 AM
  #70
dibl's Avatar
dibl
My 2018 streaked from the day I drove it off the lot. At the 5,000 mile complimentary service, I mentioned that to my service advisor and they replaced all 3 blades under warranty. That's the only warranty work I've ever needed on my Lexi.
Old Nov 19, 2020 | 05:22 PM
  #71
Cocal's Avatar
Cocal
Originally Posted by NCRX350
So is there an "official" fix for this now? I have this issue on my 2017. At first I got the usual dealer "we do not hear any problem", then went on a ride with them in the rain and got "Lexus is aware of this issues and there is no current solution". I see some of the options are a windshield coating and new wipers, and I see a new wiper arm replacement. Would love to have something to go back to Lexus with.
I have the same model year and no streaking! How old are the blades and are they the beam type? If so are they a "Good" make?
Old Nov 19, 2020 | 06:00 PM
  #72
Tarkus's Avatar
Tarkus
I have never heard of a spring getting stronger. Weaker yes. Stronger No. Is this a thing?
Old Mar 14, 2023 | 08:37 PM
  #73
BangbangP's Avatar
BangbangP
1st Gear
Recently went into this issue on my 2022 RX350... and my dealer also replied: can't reproduce the squeaky issue.
Old Mar 15, 2023 | 08:01 AM
  #74
ravenuer's Avatar
ravenuer
Usually just cleaning the windshield with a good product and replacing the blades will fix it. My experience, anyway.
Old Mar 15, 2023 | 08:41 AM
  #75
TechNut's Avatar
TechNut
Veteran: Navy
My wipers were very squeaky when new, but they have calmed down a lot with age. I don’t notice them at all any more.
almarlowe
RX - 4th Gen (2016-2022)
Mar 29, 2018 11:07 AM
Ashley0917
NX - 1st Gen (2015-2021)
Dec 25, 2016 09:30 PM
MadTweaked
IS - 1st Gen (2001-2005)
Aug 2, 2016 08:52 AM
kdsr123
Jul 20, 2012 01:16 PM
sniper5
Maintenance
Jan 6, 2011 12:51 PM
