Regular or Premium Gasoline Required?
Old Apr 18, 2017 | 06:17 PM
  #121
Mike728's Avatar
Mike728
Originally Posted by 17450
OK, it looks like I was wrong and the salesman lied to me.(you think) The sticker on the inside of the gas door does say in very small print, that I should use 91 gas. I guess I will see how much extra that is going to cost.
It's just recommended. Running 87 will not harm anything. It's recommended on the hybrid to make the advertised performance spec's. If you've been happy with it so far, no need to spend more on gas.
Old Apr 19, 2017 | 06:12 AM
  #122
jwrichter's Avatar
jwrichter
Smile /
Originally Posted by RXOwner
Sorry but it will not hurt your RX to run regular instead of premium. That is simply not true.
What he said!
Old Apr 19, 2017 | 06:13 AM
  #123
jwrichter's Avatar
jwrichter
Default /
Originally Posted by Bearcat
True, however if we can afford vehicles that are $50-65k, we can afford good gas.
Some of us got these good cars because we know how to save a buck and still purchase "GOOD" gas.
Old Apr 19, 2017 | 06:43 AM
  #124
PeeVee's Avatar
PeeVee
Our vendor told us that we can run with regular no problem, but to fill with premium from time to time to clean the injection system.
For the couple last fill up I did, I have put premium and God I like the better push the engine gives! And it consumes even less than regular.
I think I am sticking to premium in the future!
Old Apr 19, 2017 | 06:53 AM
  #125
Mike728's Avatar
Mike728
Another Canadian, so I'll ask you the same question. Do you know if your premium contains Ethanol? That could explain your improve fuel economy, as Ethanol burns quicker. Your "better push" comment is all in your head, but I've said enough on that subject.
Blending ethanol and gasoline at a ratio of 85 percent to 15 percent (E85), the blended fuel is nearly thirty percent less powerful than pure gasoline. Ethanol is similar in acceleration, power, and cruising ability, but ethanol miles per gallon are less than pure gasoline.
Link: https://www.bellperformance.com/blog...​​
Old Apr 19, 2017 | 07:01 AM
  #126
PeeVee's Avatar
PeeVee
Ethanol is 10% tops in Canada and same amount in regular and premium.
The push I am talking about may be qualitative more than quantitative, but my reference is the ECO screen in the dash board (the one showing the globe) where I can feel a nice acceleration and sill be 3/4 in the blue zone while before to get the same (before having a big hesitation to shift down the gear) I was way in the white after the blue. That is the quantitative criteria I am basing myself uppon.
So it is not in my head.
Old Apr 19, 2017 | 07:34 AM
  #127
Nail34's Avatar
Nail34
In CA the price of reg vs prem is only $.25, if you fill up (15 gal.) twice a month the cost per month is $7.50, about a price of a beer in a nice restaurant.
In most other states the difference is $.50 or more and if you fill up 4 times per month the cost is $30, then you could probably walk out of same restaurant however have someone else drive you home.
The financial point of view can vary quite a bit.
Just sayin'.
http://gasprices.aaa.com/?state=US
Old Apr 19, 2017 | 08:21 AM
  #128
LexBob2's Avatar
LexBob2
Around me premium has been .70-.90 cents per gallon higher than regular for some time. I filled up last week and it was .80 higher so it's not insignificant. So 15 gallons would run $12 higher in this case. I use premium but do question the value these days.
In any case one should know the fuel requirement and cost for a car they are interested in before purchase.
Old Apr 19, 2017 | 10:34 AM
  #129
17450's Avatar
17450
Thanks guys. Premium is .20 higher here at Costco. I think I will try it.
Old Apr 19, 2017 | 11:50 AM
  #130
ggebhardt's Avatar
ggebhardt
Have heard that using a top tier gas provider is also important and to avoid the cut rate gas stations.
Where would Costco be classified?
Old Apr 19, 2017 | 12:14 PM
  #131
17450's Avatar
17450
I believe Costco is a Top Tier gas provider. At least that's what there signs say.
Old Apr 19, 2017 | 12:52 PM
  #132
Cocal's Avatar
Cocal
Guys, where do you read that the manual "Calls" for 87? In my manual it says that you "may" use fuel with at least 91 RON (87 at the pump), that's quite different from calling for that level and it doesn't say ANYTHING about going over 91 RON which obviously means that you may. I think that you read into this more than the manual says.
Old Apr 19, 2017 | 03:32 PM
  #133
Nail34's Avatar
Nail34
In the US the manual says "87 (Research Octane Number 91) or higher" which says to me it's ok to use premium. I am not making a case for regular or premium, just pointing out that the manual says you can use either.
Old Apr 19, 2017 | 04:20 PM
  #134
Cocal's Avatar
Cocal
Agreed completely, my point was addressed to those who claim that you must use 87
Old Apr 22, 2017 | 01:56 PM
  #135
addtemp's Avatar
addtemp
I had my first Tank fill in RX 350 from Costco and can clearly feel the difference with Grade 93. The RX is running much smoother and is more responsive ...
