4RX Interesting Discoveries Thread (Good or Bad)
Old Nov 29, 2016 | 09:57 PM
  #376
s4iscool's Avatar
s4iscool
Also find the heated wheel to be a let down. Weak heat and only heats the perforated leather near the 9 and 3 o'clock positions.
Old Dec 6, 2016 | 03:20 PM
  #377
Comfort's Avatar
Comfort
Originally Posted by ericsan13
Interesting discovery...I changed the oil and filter myself this past weekend and 6.5qt came out. Per the owners manual 5.8qt is required for 450H with tow package. Is the overfill normal?
Did you check the dipstick after adding 5.8? If you still needed oil then there might be a misprint in the manual? Or is there another higher number when you include the oil filter? I would check with the dealer service dept.
Old Dec 8, 2016 | 12:51 PM
  #378
ericsan13's Avatar
ericsan13
Another discovery. When the temperature drops to 37F, the HUD and the dash light up with a "Drive carefully, roads may be icy" warning. This is similar to the message when starting the car when it's 37F or lower, but I don't recall if that warning shows up on the HUD.
I wonder if this in anyway affects the performance of the car?
Old Jan 29, 2017 | 04:05 PM
  #379
corradoMR2's Avatar
corradoMR2
The pursuit of F
Talking F-Inspired Handle Design
Coincidence or inspired?
I never noticed until my kids pointed it out!
Old Jan 29, 2017 | 04:12 PM
  #380
Bearcat's Avatar
Bearcat
i brought this up in the forums months ago. I think it's on purpose. And I like it.
Old Jan 31, 2017 | 10:47 AM
  #381
rogerh00's Avatar
rogerh00
Veteran: Air Force
Smile
Wow, Shades of Freemason/Templer hidden meanings?
Old Jan 31, 2017 | 12:14 PM
  #382
ggebhardt's Avatar
ggebhardt
Originally Posted by RXOwner
Yep, holds my calling cards and a spare pen.
Comes in very handy.
Did you also know there is another storage space under the hand rest to the mouse. I owned my RX350 for months before I found that.
Old Feb 3, 2017 | 12:13 PM
  #383
gadgetman1's Avatar
gadgetman1
Originally Posted by TexasRxh
When it rains I swear the [auto] headlights come on when the [auto] wipers start, even when it's relatively light outside (during the day). The sensor for the headlights is set 1 notch from center toward "more sensitive." I don't always think to check if headlights are on when it rains but every time I have looked they are on. Is this a hidden feature in the 4Rx or just coincidence based on my sensor settings? Has anyone else noticed this? Is it just coincidence?
(I found a post in the ES forums from 2014 with the same discussion but nowhere else.)
Many states now have a law that your lights must be on if your wipers are on. This feature solves that issue for those that might forget.
Old Feb 3, 2017 | 01:06 PM
  #384
kitlz's Avatar
kitlz
No, I don't play soccer!
Not easy to forget when it's printed on the back of the inspection sticker.
I definitely appreciate the headlights coming on when the wipers are activated. That and how they go into resting position when the RX is turned off. No more wiper blades stopped in the middle of the windshield. But it's negated somewhat by the inability to easily lift the wipers off the windshield.
Old Feb 3, 2017 | 04:19 PM
  #385
gadgetman1's Avatar
gadgetman1
I was reading my owner's manual & discovered there is a feature to make the wipers stop straight up on the glass (to change the blades). Place the ignition switch to "ON", but don't start it. Push the wiper stalk up to "MIST" & hold it. The wipers will come up completely vertical. I haven't figured out how to do the rear wiper yet...
Old Feb 3, 2017 | 05:02 PM
  #386
kitlz's Avatar
kitlz
Yes, I know about that. Within a few seconds of turning off the RX, push and hold the wiper stalk upwards. The wipers will move to the vertical position and then can be lifted up from the windshield. It's not as convenient as before, like when it's going to snow or when washing the RX. I haven't tried the rear wiper yet. But if it's anything like the 3RX, with it on, turn on the rear wiper but turn the RX off before the wiper returns under the spoiler. I put a towel under the wiper when removing the blade so it doesn't scratch the back window.
Old Feb 7, 2017 | 09:45 AM
  #387
daryll40's Avatar
daryll40
Default 2017 RX Grabs Bluetooth; 2016 Did Not
A minor gripe with my old 2016 RX was that if you turned on your phone Bluetooth, it would not "grab" it. You either had to restart the car or you could reboot the audio by holding down the power ****. The new car (2017 RX) works like my 2014 Corolla, however and immediately "grabs" the phone after turning on Bluetooth! ��
Old Feb 8, 2017 | 08:05 AM
  #388
nas2344's Avatar
nas2344
Cool little discovery, if music is paused it'll play if you adjust the volume! I thought that was cool
Old Feb 10, 2017 | 12:42 PM
  #389
gadgetman1's Avatar
gadgetman1
Perhaps this is because of different phone makes, but my 16 RX grabs my iPhone if I forget to turn on the Bluetooth after I start the car.
Old Feb 10, 2017 | 06:51 PM
  #390
daryll40's Avatar
daryll40
Nope. Same iPhone7 on both cars
