Weak windshield wash spray/passenger side/2017 RX
Old Nov 15, 2025 | 09:40 AM
LoveMyRX56's Avatar
LoveMyRX56
Default Weak windshield wash spray/passenger side/2017 RX
I've blown air, switched nozzles w new,swapped the driver to the passenger side,
the passenger side spray is just much weaker, any suggestions? The rear is good pressure as well
Old Nov 16, 2025 | 10:26 PM
Bangler's Avatar
Bangler
Maybe a clogged or broken tee, or that side hose has a hole leaking out when you use it. Or is getting pinched/collapsed but only when the hood is closed.
I would take it all out, which it sounds like you did, but I'd do it again looking for what I missed.
Old Nov 17, 2025 | 05:34 AM
LoveMyRX56's Avatar
LoveMyRX56
I didn't see any drip/fluid underneath, so I ordered a check valve where the 2 washer nozzles attach to. Had to pop off that black fiber insulation panel , and ordered new push pins too: they snap when you pop them off with a molding tool . I'll reply if this fix works
Old Nov 18, 2025 | 01:56 PM
LoveMyRX56's Avatar
LoveMyRX56
Default Windshield washer passenger side weak
I changed the check valve under the black sound insulation under hood, and it's good again.
the check valve is a black 3 prong /hose attach points .
so, about 20$ fix( the check valve 8$, and the new push pins package of 10, $12)
imagine at dealer this would be hour labor charge/$125, plus marked up parts 🙄
Last edited by LoveMyRX56; Nov 18, 2025 at 04:37 PM. Reason: More information to provide
GoingHaam
RX - 3rd Gen (2010-2015)
14
Dec 4, 2024 08:23 AM
geomike
NX - 2nd Gen (2022-current)
Jul 13, 2022 08:25 AM
ewkid
RX - 4th Gen (2016-2022)
16
Mar 18, 2022 02:35 PM
AlexNY
20
Mar 13, 2019 06:04 PM
