What is this noise?
Subscribe
Aug 31, 2025 | 12:39 PM
I have this rough noise coming from the engine (?) of my 2017 RX-350 with 100K miles:
The oil has been recently changed (the noise was present before the change too). I am using the recommended fully synthetic oil 0w20.
I am going to take it to a shop, but please share your ideas what it might be.
Reply 0
Aug 31, 2025 | 01:02 PM
I have no idea if this is the cause but here is one video explaining similar noises (note that the Highlander listed in the video I believe has a closely related fks 2gr engine. Ironically the video does not show the noise....seems like an AI video.
Might be worth a watch and a little research on the TSB.
Good luck.
Reply 1
Aug 31, 2025 | 03:51 PM
To me my car's noise is not a "knocking" but a raspy rolling noise.
Reply 0
Sep 1, 2025 | 05:57 AM
To me, sounds like bearing noise.
Reply 1
Sep 1, 2025 | 06:07 AM
It sounds like pulleys or water pump or even the belt.
Reply 3
Sep 3, 2025 | 03:28 AM
If you would like to DIY troubleshoot, try listening through a long heavy duty screw driver to help narrow down the problem location. Take a look at this video.
Reply 2
Sep 4, 2025 | 03:15 PM
Quote: It sounds like pulleys or water pump or even the belt.
He is right. Remove the belt and there is your answer.
Water pump failure is common.
Reply 2
Subscribe
