Radiator leaks are common especially on newer cars and because they often leak at the upper tank coolant evaporates and you don't see any signs on the ground. Since you drive very short distances shorten your OCI to 3,000 miles if you don't sludge and varnish will develop.
He is talking about the infamous Head Gasket leak on these 2GR's engine…
I’ve not heard of this, as a coolant leak. Might you mean the oil leak? That is where the right bank head meets the timing cover. It is more of a seep for most 3.5’s. Our 07 ES had it, and now our 18 RX. But coolant leaks were never an issue that I am aware of.
Check out The Car Care Nut on youtube. He talks about them.
Just because you haven't heard, doesn't mean it does not exists.
