hey guys I have a 2013 RX350 with heated and cooled seats in the front and they dont work. Then light isn't even on and I dont know what the problem is and Everything else works in the car. I have looked for the fuse and relay to see if that's the problem but I cant find the fuse for the heated seats ANYWHERE! It's a great option to have when the weather changes and I really wished they worked. If anybody can direct me to the fuse or if there is another problem I'm missing please let me know..Much appreciated!
Thank You
You can pull the switches out by firmly grasping the coin holder area and lifting. It slides out with ease as it is only held down by a few clips. Verify that it is plugged in! I found when I removed the shifter panel that this plug would come out very easily but is also extremely easy to put back in!
Did you look at the fuse box under the dash to the left of the steering wheel? It is a rectangular box, inside the cover is a fuse map. You will need to lay on the floor looking up with a flashlight to see it.
FYI these heated& cooled seat switches do go bad once in a while. You can get used ones on eBay. The same switch is used in a few different Lexus models. I think the IS takes the same switch.
