2010. High beam bulbs and DRL??
Hi, I just replaced my lower fog lights with LED bulbs. Now I have a conversion kit for my projector light bulb to change it to an HID with ballast. The question is I still have the factory high beam bulbs. From what I have researched the bulb gets a lower voltage to drop it down to a dim daylight running light. Is this correct? What bulb should I upgrade to? I still want DRL. If I go LED will I lose that? Is there a plug and play LED bulb that will give me both? Or should I just go with a very good Sylvania glass bulb like the Sylvania Silverstar Ultra 9005. Could you provide a link to an led bulb if so? thank you!
Do some searching as this probably has all been covered. I searched xenon and got this https://www.clublexus.com/forums/sea...rchid=21613532
Also see what is offered from Xenon Depot as they have been a long-time supporter and have great products. https://www.xenondepot.com/
Sem2315
06-11-13 02:10 AM
