RX350 Changing front turn signals
Old Jun 19, 2019 | 01:38 AM
JV6's Avatar
JV6
Default RX350 Changing front turn signals
Hello, I made a diy video on how to change our front turn signals a few months ago and would like to share it here for those who never done it before. Video could use some improvements but its a straight forward video.
I was converting my turn signals to Philips LEDs so I decided to make a diy video. There is a sneak peak of my side mirror puddle lights that I changed out to Philips bright white led. Might make a diy video for that later.
cheers
Old Jun 24, 2019 | 11:20 AM
heshamos's Avatar
heshamos
James, thanks for the video and the effort behind it.
In relation to the hyper-flashing, I have taken a different route that I would consider safer (no heat/burning-no drilling), easier (no tools needed) and it's done in less than 5 minutes.
There is a relay made for Lexus/Toyota that can replace the original one and do more than one function:
One, kills the hyper flashing
Two, gives you multiple flashing patterns when you turn the hazard signal one
Three, add a feature called "tap and turn" when you change lanes. It can be adjusted from 3 to 6 turns upon activation
and Four, it turns on the puddle lights and front and rear parking lights when you lock or unlock your vehicle.
The resistors are a bit scary to me since they must be drilled to the vehicle body and also must be touching the metal body for heat dissipation.
Here's what I'm talking about:
Link to purchase
NXOwner
NX - 1st Gen (2015-2021)
38
Oct 22, 2025 09:41 AM
NXOwner
Dec 20, 2015 12:14 PM
lbintab
Feb 3, 2014 10:15 AM
Howiefied
Jul 8, 2011 06:23 AM
taleh
RX - 3rd Gen (2010-2015)
Feb 15, 2011 06:15 PM
