Wireless key won't open back door
Old 03-10-18, 02:17 PM
tvcmluff
tvcmluff's Avatar
Default Wireless key won't open back door
Is there a way to reprogram the wireless key? All functions work properly except for opening and closing the back door. Both keys. 2012 RX 350
Old 03-11-18, 04:43 AM
tempestv8
tempestv8's Avatar
Does the power tailgate operate if you press the button inside the cabin?
salimshah (03-11-18)
Old 03-11-18, 08:35 AM
tvcmluff
tvcmluff's Avatar
Yes - the back door opens with inside button and with the button on the door itself.
Old 03-11-18, 03:17 PM
tempestv8
tempestv8's Avatar
OK, so we've established that the motor itself works fine and the activation process with the button from the cabin works fine, but not via either of the two remote keys.
Did it use to work and doesn't now?
If the vehicle is new to you, you might not know that you need to hold down that tailgate button on the remote until the hazard lights flash and the tailgate opens. Just pressing the button momentarily will not activate the motorised tailgate.
Old 03-11-18, 05:36 PM
ukrkoz
ukrkoz's Avatar
Back door, not tailgate, right? As it somehow steered towards tailgate, not rear door.
Check simple. Is child lock engaged? Though it would have prevented it from being unlocked from handle or button inside but hey...
Otherwise, as key does not differentiate between specific door, it opens all or none (my Dodge RAM open driver door with the first click, then all with the 2nd) - you have continuity problem from remote lock module to that particular door. Likely easiest is to remove door trim, get to the lock plug and see if 12V is triggered when remote button is pressed.
Old 03-12-18, 08:08 AM
tvcmluff
tvcmluff's Avatar
i have pressed and held the button on both of my keys and neither work.
Old 03-12-18, 08:11 AM
tvcmluff
tvcmluff's Avatar
Have pressed and held the button on both keys. No dice. Car is new to me and the tailgate/trunk door has never opened with the key. Will check the other things suggested. Thanks.
Old 03-12-18, 10:11 AM
HaywardLex
HaywardLex's Avatar
I'm still confused, are you talking about the back doors or the rear hatchback ? If it's the hatchback door there is a button in the glove box that disables or enables that function, but even then you have to hold the key fob hatch button until the lights flick
Old 03-12-18, 11:25 AM
salimshah
salimshah's Avatar
Its clear now that you are talking about the trunk/hatch.
There are few more details missing:
1. Release/lock. Do you hear that operating. Move the key-fob away and see if you can lock/unlock with the inside button. Then check if it locks/unlocks based on how you have programmed the RX (lock when you move out of Park).
2. Lift/close motor. Does that operate with the driver button. .. there is safety button in the glove compartment to disable/enable power lift/close
3. Now check the key-fob. Open- also unlocks the vehicle (may or may not be a programmable option).
Salim
Old 03-12-18, 02:51 PM
tempestv8
tempestv8's Avatar
The tailgate/hatchback disable button in the glove compartment would disable the opening of the tailgate via either the remote key fobs or the interior release button. In this case, the glovebox switch must surely be in the correct position as the tailgate can be opened by the interior release button, just not either of the remote key fobs.
Maybe the batteries in both the keyfobs are low and cannot sustain a constant transmit when that button is needed to be held down for a few seconds. My suggestion would be to replace at least one of the batteries with a fresh CR1632 battery. This will only cost a couple of dollars.
Old 03-12-18, 03:05 PM
tn7con
tn7con's Avatar
Using the keyfob, try to press the door unlock buttons twice to unlock all doors/liftgate. Then press & hold the liftgate button for a few seconds to open the liftgate ...
Old 03-12-18, 03:58 PM
tvcmluff
tvcmluff's Avatar
Sorry everyone. I’m referring to the lift gate/back trunk door
Old 03-14-18, 02:15 PM
ukrkoz
ukrkoz's Avatar
Ok, thank you.
So now you need to clarify two more questions:
1. When you press and hold liftgate button on fob, does it open?
2. when you press Open button on fob, do all DOORS open but liftgate does not? As in - STAYS LOCKED?
Old 03-14-18, 02:28 PM
tempestv8
tempestv8's Avatar
If you looked at the preceeding responses, this question has already been addressed twice.
and then
Old 03-15-18, 06:15 AM
tempestv8
tempestv8's Avatar
OK, might have found the reason. The back door operation can be customized by the dealer as follows:
Power back door
After all the doors have been unlocked, the rear door can be programmed for the following:
a. After momentarily pressing the rear door release button on the remote key, the rear door will open.
b. After pressing the rear door release button twice on the remote key, the rear door will open.
c. After pressing and holding the rear door release button on the remote key for 0.8 seconds, the rear door will open. (Standard)
d. The rear door, release door button is turned off and will not function
It is likely that your key has been programmed to either setting d, or maybe possibly setting b. You can test this out simply by double pressing the tailgate release button on your remote key.
See this document for full details of this customization and others: http://www.lexus.com/pdf/service/RX350_LPS.pdf
These are the parameters if you have access to a Techstream
Credit for this information goes to the participants on this existing thread: https://www.clublexus.com/forums/rx-...nk-door-3.html
salimshah (03-15-18)
Phariskam
Hybrid Technology
01-15-19 10:40 AM
Dx3
10-23-14 07:33 PM
gs350trev
07-28-14 10:00 AM
bozer
07-15-07 03:20 PM
Sunsoul
10-18-04 04:41 PM
Quick Reply: Wireless key won't open back door
