front seat wobble
front seat wobble
Are the seats supposed to shake when you hit it? I'm sure there is a free play if you hit something with blunt force. But I just noticed this morning that when I shake the seat with some force, the whole thing wobbles pretty good. I don't hear any sounds nor do I see any movement on the seat tracks. Do you think it's within tolerance?
Did you compare it to the other seat? If the same, then no problem. If it shakes more you may have a problem. Anchor bolts could be loose, or one of the motor assemblies has an issue. If you sill have a warranty left, go to the dealer. Otherwise, I would try a body shop.
