Transfer case on 2014 RX 350
Old Sep 8, 2016 | 05:42 PM
pinkivy98's Avatar
pinkivy98
Default Transfer case on 2014 RX 350
I recently purchased a 2014 RX350 with 30k miles not certified from a Subaru dealership. I noticed whenever I go above 60 mph then press on the break to start slowing down the vehicle feels like I am going over small speed bumps. It was first suggested that I needed brake pads & rotors for the front. I had that installed & the problem started back after a week. It was then suggested it was the transfer case. I have never heard of a transfer case. I have an appointment with a Lexus dealership to check it but I wanted to see if any owners have had this problem.
Old Sep 13, 2016 | 11:43 AM
vlad_a's Avatar
vlad_a
FYI, RX does not have a transfer case. Only 4x4 trucks and SUVs do. It's function is to manually switch between 2WD and 4WD modes.
Old Sep 13, 2016 | 01:37 PM
Clutchless's Avatar
Clutchless
If you have AWD, then there is a transfer case located next to the automatic transmission. However it is fully automatic in operation and just needs the fluid checked and then changed once in a rare while. I think the problem is now that your rear brake rotors are also warped or have pad build up that is causing the bump bump feeling when you brake. Or else, the new rotors are getting warped or have pad transfer already, but that is unlikely. I think the dealer will be able to sort it out as you still have lots of warranty left.
Old Sep 13, 2016 | 02:54 PM
pinkivy98's Avatar
pinkivy98
Ok thanks! I have an appointment with the dealership this Friday.
geefish
RX - 4th Gen (2016-2022)
56
Oct 14, 2021 11:58 AM
joeshome
Apr 8, 2019 05:26 PM
mwc951
RX - 3rd Gen (2010-2015)
16
Nov 11, 2014 04:06 PM
PigSnack
Aug 12, 2012 09:47 AM
vp911
RX - 1st Gen (1999-2003)
Dec 23, 2005 10:47 AM
