Rear Diff seal leak
Old Dec 10, 2015 | 06:26 AM
2010morx's Avatar
2010morx
Default Rear Diff seal leak
Just an FYI. Our 2010 AWD RX350 developed a rear differential oil leak (passenger side) at the drive shaft lip seal. Has 80,000.
Old Dec 10, 2015 | 07:07 AM
Clutchless's Avatar
Clutchless
Things do wear out eventually. How bad a leak was it? Have you had it repaired? How much to replace the seal?
Most such leaks just make the differential wet and drip so slowly you can just top up the fluid every year. I did that on my 95 Explorer for several years. It only took 5 minutes to add more fluid.
Old Dec 10, 2015 | 04:46 PM
carguy75's Avatar
carguy75
Bummer.
Easy fix to do if you can DIY though.
Old Dec 11, 2015 | 09:14 AM
2010morx's Avatar
2010morx
When I noticed it, there was about a half ounce on the garage floor. My best guess was it was about 1-2 oz. low. I bought it as a CPO. Had the free 24 hr. road service so I had it towed on a flatbed to the dealer just In case (didn't want to run it dry). Seal was replaced under warranty.
Cost if not under warrant was $375. Took 2 days with a nice 2015 loaner. All is well
Old Dec 11, 2015 | 09:22 AM
2010morx's Avatar
2010morx
Yeah, I didn't expect an oil seal to fail at 80,000 mi., so I thought I let you guys know as a heads up. Did notice that my 2010 drove just as nice as the 2015 RX350 AWD loaner with 20 mi on it.
Old Dec 12, 2015 | 06:56 AM
carguy75's Avatar
carguy75
Happy it was a simple problem after all.
Only $375 to repair at the dealer, like I said earlier easy job to do if someone had to do it at home.
Most of that cost was mostly labor cost, and it only took as long as two days I bet because they may have had to order the seal since it seems like a very rare issue to happen and the dealership parts section probably did not have any of the axle seals in-house.
However, if someone have not ever done any axle work on a car then it would be better to just pay Lexus to do it.
213374U
Jan 22, 2019 10:31 AM
SMCK
Jul 6, 2018 01:35 PM
nch2oracer
Feb 12, 2014 06:59 AM
mcat
Aug 16, 2013 08:00 PM
Gomer1
RX - 1st Gen (1999-2003)
Jun 11, 2007 01:40 PM
