Changing Interior Lights
Old Aug 6, 2013 | 10:54 PM
Sh1nra's Avatar
Sh1nra
Default Changing Interior Lights
Hey guys, I'm having trouble removing the dome and footwell lights. I'm able to remove the cover (except the back passenger cover, can't seem to find a way to remove it) but as far as removing the lights, I can't tell if I should push or pull it.
I've asked the Lexus dealer to show me but they will not due to safety issues.
Car: 2013 Rx350
Old Aug 7, 2013 | 08:47 AM
kitlz's Avatar
kitlz
No, I don't play soccer!
Sh1nra, can you post pictures of the areas in question? I don't think there are any drastic changes from '10-'12 but I'd like to see it before making any suggestions.
Old Aug 7, 2013 | 05:27 PM
Sh1nra's Avatar
Sh1nra
Footwell:
Dome:
As for the rear passenger lights, I'm still trying to figure a way to take the cover off.
Old Aug 7, 2013 | 05:44 PM
kitlz's Avatar
kitlz
Thanks for the pics. I think you have them reversed. To remove the bulbs, pull them straight out. Do not twist them, especially the front dome or else the housing will come loose. You can see the black tabs that hold it in place. When you say rear passenger lights I assume you mean the ones on the door. I used my trusty plastic card (like what you get from stores) and slid it around the edges to release the tabs. It was easy and didn't scratch anything. For the rear dome I went with a thin metal tool to slide around the cover. Others used a small screwdriver. Good luck.
Old Aug 7, 2013 | 11:30 PM
Sh1nra's Avatar
Sh1nra
My bad! I didn't notice until you pointed it out. I see. Corrected it.
Will try to pull it when I get the chance.
Yea the rear dome lights. I can't find anything thin enough to slip into the crack.
Dolphin
RX - 3rd Gen (2010-2015)
39
Apr 20, 2016 06:00 PM
rebecca350
RC - 1st Gen (2015-present)
Mar 30, 2016 02:37 PM
myonoshane
Nov 3, 2014 08:40 PM
homoonar
HS 250h Model (2010-2012)
Sep 9, 2013 06:55 AM
tastemydus
IS F (2008-2014)
Oct 12, 2008 05:39 PM
