RX offroading video!
One wheel off the ground...lots of wheel spin with minimal forward motion.
I was thinking for a bit you'd make an excellent judge to make the justice system more efficient. Each side has 0.5 seconds to state their case before the gavel goes done for judgement.
But seriously, as a whole though, I do take a little issue with these gimmicky videos (another one comes to mind is the one with various SUVs going up a 30% incline coated with specially prepared sheet ice) as definitive evidence of inferior design.
To have an inferior design, the design must not meet the design goals. If the design goal was to be able to drive up 30% inclines of specially prepared sheet ice, or free itself from rollers in a parking lot, clearly the RX fails miserably. But obviously these were not the design goals, nor was off-road driving as clearly Lexus does not recommend it. So what are the design goals of RX AWD system? Unfortunately it does not seem that Lexus makes much comment about that other than the little bits from marketing (and what do they know about cars
)What I could find just as often or more so talks about their AWD system as being more fuel efficient with less parasitic loses, better functioning with VDIM (ie stability control systems), better driveability in tight corners as well as the obvious "improved traction". If the design goal is somewhere in here, then to pronounce it inferior the RX must roll over more often, get worse gas mileage, be rougher in tight corners, and suck more with everyday traction challenged situations.
Clearly someone that is looking for a vehicle that performs well in situations of 0.0001% dry traction situations, the RX is a very poor choice, but to pronounce it inferior, I don't think the right evidence is being considered...
