Premium for 2010-2011 RX350? (merged threads)
I find this quote interesting from the FTC: “In most cases, using a higher-octane gasoline than your owner’s manual recommends offers absolutely no benefit. It won’t make your car perform better, go faster, get better mileage or run cleaner.”
I've done some reading on the fuel octane to use and from what I have read 87 octane is fine to use. But when I opened the fuel cap is says "PREMIUM UNLEADED FUEL ONLY". Should I use 91 Octane or 87?
2011 RX 350: Only Premium in WV hills.
Lexus marketing just thought their luxury vehicle should carry a higher hp rating than a pedestrian Toyota. Unless you're drag racing, towing, or have another requirement for the extra few hp, there's really no need. The last 200,000 miles on my 235,000 mile 2010 have been on 87 octane - no issues, and confirmed OK with Lexus service.
As the owner's manual says
[/QUOTE]
Weird because these are from the 2011 RX350's owner manual, not to mention the premium unleaded fuel sticker by the gas cap. I'm sure you got your money's worth from using 87 instead of 91 though.
It is like saying that a product like a table needs at the minimum four screws to be stable and bear a certain weight, but using more than four screws would make it more stable and increase it load bearing ability with the additional number of screws used beyond four. Do that mean that the table is only design for four screws? No, it means that the table will work at it minimum ability with four screws. However, it will perform at a high potential in relation to number of screws used over the bare minimum four needed.
The same for the Lexus RX350 engine. It will run fine and at its minimum acceptable performance level with 87 octane, but the engine should run better as the octane increases.
If the instructions to assemble a table require a minimum of 4 screws and you only have 3, then you're SOL. Yes, you can still make 3 screws work, but is it the same as 4 screws? No.
At the end of the day, the 3rd gen RX350 still receives lots of praise for its reliability and I doubt the target audience for original owner RX350s cared enough to look at the manual.
Hence why these octane debates never really ends with a true winner on either side of the debate.
