RX450H Reverse light power needed for trailer wiring
I recently installed a hitch and lights for my new 2011 RX450H but am in the need for the reverse light to also be on the plug for the trailer as needed for my boat trailer. The plug for the basic wires worked perfect and I cut off the standard 5 prong end (4 and ground) and replaced with the 6 prong flat (same as the standard with reverse added). The problem is where to get the power to trigger the reverse light as this is not in the harness used with the kits. Before I route a wire from the rear door all the way down to the spare tire area, does anyone have a wiring schematic for the 450 that shows the route for the reverse lights power?
Sorry for the long winded questions, but figured it helps explain the whole question.
Thanks,
Ray
Thanks,
Ray
SCott300
SC- 1st Gen (1992-2000)
09-06-11 04:23 PM
