Part ID help?
Old Apr 29, 2026 | 10:23 AM
RXraoool's Avatar
RXraoool
3rd Gear
Default Part ID help?
Greetings,
Just bought a 2015 RX350 base (after sad goodbye to my '08 after 220K miles ^sniff). Would appreciate if you could ID the part highlighted in the photo - passenger side of engine. The cover/bushing/rubbery washer type gasket thingie (heads up - not a tech!) on the engine side is not flush. Curious if that's a concern?
Thanks in advance.
rubbery cover/washer loose. issue?
Old Apr 29, 2026 | 12:46 PM
MattRX's Avatar
MattRX
It's just a loose little rubber isolator, maybe it's to protect it from water or reduce noise etc. Mine's the same way, it's fine and normal.
What happened to the 2008? I still have both! How are you liking your 2015 vs. the 08?
Old Apr 30, 2026 | 08:36 AM
RXraoool's Avatar
RXraoool
3rd Gear
Thanks for the response.
The '08 remains a mystery. Couple months back on cold start had misfire/serious shake. Turned it off and back on again (I'm in computers - doesn't that fix everything?! . Started/ran fine. Next day - no shake, but CEL. OBD showed evap code so replaced gas cap. Fine for month until - this time 1/2 hour into highway drive - started shaking again. Pulled over, turned off. Tightened new gas cap (was fine). Started up ok. Again no OBD codes. Had local guy (new to me - tried because he was closest with full diags suite and good rep) review. Said he was able to capture live misfire on 2&4 'under really heavy load' - though still no stored OBD codes. Suggested plugs (hadn't been done in ~100K miles so I agreed/maybe back 3 ignition coils while you're in there?. Once he got in, called up with all sorts of stuff which mostly made sense (gasket, plugs, coils, maybe injectors...) with estimate to $5K. Was ready for tires (+$1K); hood had some aesthetics issues (another $1K...). Just took it as a sign it was time. 17 years, 220K miles. Nicest and prettiest (brandywine - new one's nebula/grey) car I've ever owned. Still don't know if 'we buy any car' is gonna make some nice $; but given the mystery, couldn't in good conscience offer it privately. Kept telling them I took a Camry to 400K miles with same care!
Still acclimating to the '15. First long ride coming this weekend. Is base model so already missing things/short term buyer's remorse.. (no heated seats!?! wtf!?). Some silly things on order (window visors, wide angle mirror stickons, phone holder...) hoping to restore some of the familiarity/comfort to which I'd become accustomed. Stellar (mostly Lexus dealer) maintenance history but sporadic tremor. Others swear they don't feel it (guess my butt's sensitive from 17 year spoilage). Suspect tire flat spot (been sitting for 6 months) but comes and goes...
Thanks again for the response.
Old Apr 30, 2026 | 10:00 AM
MattRX's Avatar
MattRX
Darn, sorry to hear! 5k seems a lot for that kind of work - but it sounds like you definitely got your money's worth out of her! Kinda surprised the 15 has no heated seats! I've seen 10-12 without them but never a 13-15. Does it have a sunroof or fog lights? My 2008's a base but it has heated seats, but that may because it is a Canadian car vs. US spec. Although, I did see a 2007 at the junkyard once that didn't have them, memory seats or a sunroof. I would love to have a slicktop RX, as the heated seats can be added later as I found on my friend's RAV4 after some simple wiring.
Old May 1, 2026 | 09:12 AM
RXraoool's Avatar
RXraoool
3rd Gear
'08 certainly served me well. '15 does have sunroof and fog lights.Lack of heated seats surprised me too - adding those probably #2 or 3 on the ToDo list (after basic everything maintenance-wise and maybe external detail to address some minor scratches/cosmetics). Already growing on me.
Ducatiguy100
RX - 3rd Gen (2010-2015)
Jun 29, 2025 05:52 AM
TheLilJohn
GX - 1st Gen (2003-2009)
Oct 20, 2024 03:13 PM
HobieMarty
Dec 27, 2022 05:54 PM
Protholl
Jul 18, 2021 05:03 PM
crsow
Aug 19, 2003 10:06 AM
