Idiot lights will not go off!
Old Jan 6, 2026 | 02:07 PM
Raptor5's Avatar
Raptor5
1st Gear
Default Idiot lights will not go off!
I am at my wits end about this problem! Sometime ago, my 2011 Lexus with 146K miles on it suddenly displayed three idiot lights, which will not go off no matter what I do. The first light is a standard check engine light. The second light looks like a car swerving in a bunch of directions, and the third is a warning on the message Light that says check all wheel drive system. I did change the batteries sometime ago and the lights went off and stayed off for about a week at which time they came on again. This is driving me nuts since I want to sell the car and I don’t want to give another person this problem. Does anyone have any information about this problem?
Old Jan 6, 2026 | 05:46 PM
salimshah's Avatar
salimshah
25 Year Member
Check engine light is telling you that there are error codes that the computer has stored and proper diagnosis and repairs are needed.
Usually you can read them through a device called OBDII reader and many shops do a complimentary read for you. Keep in mind most people just think that replacing the sensor will fix the problem but it might not. All the computer tells you that an abnormality has been recorded.
Most mechanics refer to it as money light.
The accompanying lights that you are seeing come on as those functions may be disabled due to the error condition.
Salim
Old Jan 7, 2026 | 04:55 AM
2012rx350Ed's Avatar
2012rx350Ed
4th Gear
Salim
You may wish to check the condition of your gas cap. A faulty gas cap can result in displaying several warning lights on your dash. If you do not hear two rather distinct clicks when putting on the gas gap...it may be sign that your gas cap is faulty.
Old Jan 7, 2026 | 04:45 PM
carguy75's Avatar
carguy75
Like mentioned above; the first step is to use a code reader to see what errors are that is triggering the warning lights.
My guess is that you may have a bad speed sensor due to the traction control and AWD warning lights.
wgrussell
GX - 2nd Gen (2010-2023)
Dec 17, 2017 07:03 AM
Sp77641
Jan 20, 2015 06:51 AM
itztwinki3
Aug 3, 2014 01:54 AM
khizr23
May 5, 2014 11:22 AM
