Left turn signal won't quit
Old May 26, 2025 | 05:27 AM
wyciwug's Avatar
wyciwug
2nd gear
Default Left turn signal won't quit
Left turn signal on my 2015 won't quit but when I turn on the right signal, both sides blink as if the emergency button is press.
I removed the cover for the steering column and unplugged the white connector to the turn signal switch. The left side continue to turn but turning right side signal no longer worked. Is it the problem with the turn signal combination switch?
Thanks
Old May 26, 2025 | 08:00 AM
RX in NC's Avatar
RX in NC
Probably a switch issue. Disconnect all wires into it, spray those connectors with electrical contact cleaner spray, reconnect them, and see if that makes any difference.
Old May 28, 2025 | 07:58 AM
wyciwug09's Avatar
wyciwug09
4th Gear
I could not log in my previous account so I am replying from here.
I saw others have the same exact issue in a facebook group after heavy rain.
Old May 28, 2025 | 09:22 AM
RX in NC's Avatar
RX in NC
Clear your sunroof drains if you suspect rain is causing your problem. Always a good idea to clear those drains on an annual basis.
Old May 29, 2025 | 07:14 PM
wyciwug09's Avatar
wyciwug09
4th Gear
did that on sunday, wait to see if the turn signal problem will go away, so far not yet. The Blind spot sensor light stays on even after BSM is off too.
vrntch
RX - 3rd Gen (2010-2015)
Jul 25, 2024 11:52 AM
mercigermans
Feb 3, 2024 09:48 PM
Ham
Nov 15, 2022 01:18 PM
Knightfall
Aug 18, 2021 11:46 AM
shawnlexus
Aug 24, 2010 08:48 PM
