13 RX350 Noise
Old May 21, 2025 | 04:39 AM
10156EppersonWay's Avatar
10156EppersonWay
1st Gear
Default 13 RX350 Noise
It’s always been a little noisy at startup, has gotten worse lately. It usually goes away as the car warms up.
File Type: mov
Old May 21, 2025 | 05:03 PM
carguy75's Avatar
carguy75
Take your RX350 to a mechanic. All we forum members can do is guess to what it "may" be.
The best solution to your problem is to have an mechanic do an actual in-person inspection of your engine; maybe two different repair shops to be certain that both shops recommend the same repair.
Old May 21, 2025 | 05:10 PM
RofH's Avatar
RofH
If possible, take to a Japanese Specialty Shop if you don’t want to go to your local dealership.
EDIT:
It would be helpful if you gave more background info like how long is “always”?
How long is “lately”?
And how long has it “usually goes away as the car warms up”?
Old May 22, 2025 | 05:23 AM
Clutchless's Avatar
Clutchless
How many miles are on it?
The noise often called the death rattle at startup has been discussed many times and is usually blamed on a few different sources among them the VVT valves- filters, oil filter, not changing oil enough etc.
See these prior threads:
​​​​​​https://www.clublexus.com/forums/hyb...up-rx450h.html
​​​​​​https://www.clublexus.com/forums/hyb...cold-soak.html
​​​​​​https://www.clublexus.com/forums/rx-...ine-knock.html
​​​​​​https://www.clublexus.com/forums/rx-...d-startup.html
Old May 22, 2025 | 08:32 AM
Roscol's Avatar
Roscol
Sounds like something serpentine belt related.
Remove the belt, start the engine and go from there. You’ll be able to rule out or confirm if it’s the water pump, tensioner/idler, alternator.
my1s250
RX - 4th Gen (2016-2022)
Dec 29, 2024 01:04 PM
rns
Hybrid Technology
13
Mar 31, 2023 07:42 PM
Freds430
RX - 3rd Gen (2010-2015)
Dec 25, 2013 09:27 PM
pinoiryder
Feb 7, 2011 09:50 AM
nardeezy
Mar 29, 2006 07:32 AM
