transmission fluid change
Old Jun 4, 2025 | 06:17 AM
mullising's Avatar
mullising
5th Gear
Thanks Clutchless. I read the articles regarding drain and fill on a cold fill, but don't want to take chances trying it myself. My Lexus dealer said that either I should have done it from the very beginning starting at 30K or don't do it at all. I don't agree though. I will definitely talk to my mechanic, which is a small shop. His mom and dad have an RX350.
Old Jun 4, 2025 | 06:43 AM
Clutchless's Avatar
Clutchless
Understand your position. Let us know how you get the fluid changed and if your guy can do it. I suspect he can, or may want to learn how to do the drain and fill.
Old Jun 8, 2025 | 05:46 AM
erapmicks's Avatar
erapmicks
drain and fill once with ATF WS only.
do it again after 60k miles.
Take it easy on drain and fill. youd want the clutch materials in there. just change some
Old Jun 8, 2025 | 07:36 AM
salimshah's Avatar
salimshah
25 Year Member
There are plenty of theories about changing or not changing the transmission fluid and you can spend days searching and reading. You are welcome to form your own opinion [why not?].
Without adding my personal opinion I will only state the distilled popular opinions here [I will repeat popular which may be or may not be correct].
1. There is no lifetime fluid.
2. Do not power flush the transmission fluid.
3. If you already have high milage [high milage is undefined], leave the fluid untouched [only fill if needed]. <- this is the item you seem to disagree with
4. If you do replace, make sure the fluid level is proper. [volume/level is temperature dependent].
Choose wisely.
Salim
PS: I don't have a horse in this race. I chose 450H as it has totally different transmission.
Old Jun 8, 2025 | 07:59 AM
erapmicks's Avatar
erapmicks
Choose wisely.
Salim
agreed.
if you do drain and fill, make sure do the proper procedure via "Pin" method or Car reader that reads live data. lots of youtube vidoes on HOW TO. I would not trust anyone else doing this but myself
Old Jun 8, 2025 | 09:59 AM
erapmicks's Avatar
erapmicks
Originally Posted by erapmicks
agreed.
I been using scangauge 3 for my temp check when i do drain and fill on my rav4 and rx350
LxLimo
LX - 4th Gen (2022-present)
Mar 27, 2024 11:20 AM
abaitedcat
Sep 3, 2019 09:10 AM
ALLCHILL
Dec 9, 2014 02:50 PM
advsystems
Maintenance
Aug 31, 2004 03:14 PM
dumdumgreg
Jun 20, 2002 02:16 PM
