low beam level 2013rx 350 fsport
Old Jan 19, 2025 | 03:02 PM
abdelrahmanmortada's Avatar
abdelrahmanmortada
9th Gear
Default low beam level 2013rx 350 fsport
CAN I GET latestet updates software for multimedia, maps& transmission from places outside dealership in north VA ?
AND MY XENON LIGHT IN LOW BEAN IS LOOKING DOWN I DUNNO HOW TO control the level
2013rx 350 fsport
Old Jan 20, 2025 | 05:49 AM
Clutchless's Avatar
Clutchless
See these links: Also you need a dealer to do software updates. You could try Satelite motors in Silver Spring, Maryland as they are a Toyota specialist but I doubt they do software updates.
Also it may be time to replace your D4S HID low beam bulbs as they get dimmer over time and it is a subtle change. You can find OEM style philips or Toshiba bulb online.
https://www.clublexus.com/forums/rx-...placement.html
​​​​​​https://www.clublexus.com/forums/rx-...ht-sensor.html
​​​​​​https://www.clublexus.com/forums/rx-...headlamps.html
https://www.clublexus.com/forums/rx-...d-threads.html
Old Jan 20, 2025 | 07:58 AM
salimshah's Avatar
salimshah
25 Year Member
Default my 2c on headlight spotting
It is a never ending game once you get into it based on human perspective. Some may insist that they know when it is good they can skip over this post.
One needs proper instrument to measure and set. Every inspection station/mechanic used to have the thing that they would roll up to the vehicle, but I have not seen them being used so I am skeptical about their instrument to be calibrated right.
So I suggest, fill up your tank and take your vehicle to a reputable body shop [or dealer of your choice] after confirming they have the instrument calibrated and have the specs for your vehicle. Should be 1/2hr labor with the actual time even less.
Salim
Old Jan 20, 2025 | 11:09 AM
Clutchless's Avatar
Clutchless
Here is an independent Toyota specialist in Manassas VA that has a top rating from Washington Consumers Checkbook.
Fix Your Toy Auto Repair
9203 Enterprise Ct #O
Manassas Park, VA 20111
703-330-2886
Jbski19
NX - 2nd Gen (2022-current)
Jan 24, 2024 10:37 AM
Nicholas12
RC - 1st Gen (2015-present)
Dec 15, 2020 08:49 PM
alexlude
Jul 18, 2017 05:24 PM
FrOHiKE
Dec 5, 2014 02:58 PM
Therealman
Jul 5, 2013 08:39 PM
