2010 RX350 cylinder problems
I did a pressure test myself and can confirm the leak. Also white smoke out of exhaust. I tried looking at the oil and it seems more chocolate colored than normal but not 100% sure.
I took it to one more shop about 10 miles away who did another borescope and confirmed the coolant leak but gave me a really high labor cost for just diagnosing further - eg if it's just head gasket or needs an engine( $3000 ) . I called the dealer who wants 5500 for diagnosis !
I do not think it is worth it at this time. I can't keep driving it around to shops either and would need to tow it - it overheated a couple of times while driving back from the above mentioned shop - I pulled over and stopped for a bit then made it home.
I plan to call one more shop next week but right now my thought is to just replace the car. The car also has some minor body damage because I dropped collision on it a year ago and as luck would have it - someone hit my car and drove off
.The main issue is trust and finding a good mechanic .
At this point I am just going off some recommendations for independent shops who apparently are not that interested as soon as they hear the age of the car. I even called a shop that apparently specializes in Japanese cars and he just said he doesn't even look at coolant leak issues but sends it to the dealer
I heard there are products for leaks ( K-seal ) etc but I also see bad reviews about them . At the most this may be short term solution ?
Thank you all so much for your help - it was invaluable.
If anyone has any ideas on what I could have done to prevent this , that would be much appreciated too. I did the normal recommended maintenance/oil changes so far .
The 3.5 V6 is a reliable V6 engine(up to about 200k miles), but is not immune to problems with higher mileage(over 200k miles) that may require a rebuild or gasket replacements.
Note: It is odd tha the dealer service center did not notice the weeping coolant(or drop in coolant level) before as they were servicing your RX350 regularly and should have inspected the engine fluid reservoirs like the engine coolant and brake fluid during those visits. Hopefully the service center did not notice the coolant issue and decided to wait to tell you until it became a major issue for you to pay them to repair it.
