Check AWS System
Old May 2, 2024 | 03:50 PM
Kostyan's Avatar
Kostyan
Default Check AWS System
Guys.
2013 RX with just around 100k mi on the clock. Check AWS system warning light came on while driving on highway at 70-80mph. Light went off after restart but came back on return highway trip. Light never showed back up next day during local driving.
scanner A shows alternator charges at 13.2 volt when motor is spinning at 2000rpms but did not show aws fault.
scanner B showed AWS fault code c1299.
battery voltage is 12.89.
any ideas what this might be?
Old May 2, 2024 | 10:41 PM
salimshah's Avatar
salimshah
25 Year Member
Google found this for me
https://www.engine-codes.com/c1299_lexus.html
It has few steps that you can take to eliminate.
Salim
Old May 4, 2024 | 04:17 PM
Kostyan's Avatar
Kostyan
Salim
thank you Salim. My tire sizes are the same, tire pressures are within norm otherwise it would trigger tpms light on the dash. I first suspected alternator going out because my reading is on the lower side at 13.2 volt at 2000 rpms. Looks like i wont be able to diagnose it myself and will have to take it to the shop.
jagiovana
Oct 7, 2019 09:54 PM
Tungstn-IS
Mar 10, 2014 11:29 PM
RX7 RAGE
IS F (2008-2014)
Mar 1, 2012 10:17 AM
taliz29
GS - 1st Gen (1993-1997)
Jul 26, 2007 04:59 PM
