LED Headlight Conversion...
Old Aug 21, 2023 | 09:47 AM
KenSpringTx's Avatar
KenSpringTx
Default LED Headlight Conversion...
Team, curious if anyone has done the LED headlight (bulb) conversion or upgrade..? I tried searching and didn't find anything... I did these to my 2011 Armada and it was night and day... I'm unsure of the BASE models bulbs and if its even worth considering ... your feedback is always appreciated.. Thanks in advance.
Old Aug 21, 2023 | 12:04 PM
Clutchless's Avatar
Clutchless
If you have HID bulbs, keep them as they are better than LED. Just get new bulbs as the old ones get dimmer over time. They are the D4S bulbs.
If you have halogen, they are H11 and the first thing you need to do is figure out which bulbs you have.
See this older thread https://www.clublexus.com/forums/rx-...eadlights.html
Or go to the Lexus Drivers Site, join and enter your VIN to see the build sheet that shows the options. It can be a base model (all of them are base models unless you get an F Sport) and have either headlight option.
​​​​​​https://www.lexus.com/My-Lexus/account/create-account
If you have H11 you are better of doing the H9 bulb conversion. You can Google H11 to H9 conversion. Many forums discuss it.
Or hunt around and experiment with some H11 replacement LED bulbs and hope you see better. I tried them on my HS250h and did not like the results and went back to H9 as I could see better. The light pattern was terrible with the LED bulbs.
Old Aug 21, 2023 | 08:00 PM
KenSpringTx
Thanks again No Clutch! Ill keep you all in the loop!
Old Aug 21, 2023 | 08:18 PM
KenSpringTx
Clutch, I went to the Lexus site and did not see any headlight info... should I assume H11? details below... thanks again!
BODY TYPE
Wagon
MODEL
RX350
DRIVE TYPE
2WD
TIRE SIZE
60R18
ENGINE
6-Cylinder
EXTERIOR
NEBULA GRAY PEARL
TRANSMISSION
6AT
INTERIOR
PARCHMENT
DATE OF FIRST USE
2014-07-31
ADDITIONAL VEHICLE DETAILS
ORDER DATE
05/2014
BODY STYLE
5-DOOR SUV 4X2
PLANT OF MANUFACTURE
PORT- OR FACTORY-INSTALLED EQUIPMENT
Z1 CARGO NET,CARGO MAT,WHEEL LOCKS & KEY GLOVE
Port
STANDARD INSTALLED EQUIPMENT
STANDARD FEATURES
3.5 Liter 270HP Four Cam 24-Valve V6 Engine with Variable Valve Timing (VVT-i) 6-Sp Automatic Transmission w/"Snow Mode" 18" Aluminum Alloy Wheels Tire Pressure Monitoring System 10 Airbags: Driver & Front Passenger: Front
Knee & Side (6)
Rear Side (2)
Side Curtain (2) Anti-Lock Braking System (ABS) with Electronic Brakeforce Distribution (EBD) & Brake Assist Automatic On/Off Headlamps/Integrated Fog Lamps LED Daytime Running Lamps (DRL) Vehicle Theft-Deterrent Sys w/Engine Immobilizer Safety Connect: Automatic Collision Notification
Stolen Vehicle Location
Emergency Assist Button (SOS)
and Enhanced Roadside Assistance (1-year trial subscription included) Lexus 12 speaker Premium Display Audio System
HD Radio w/ iTunes tagging
USB iPod/MP3 Control
SiriusXM Satellite Radio (90-day All Access trial subscription included) Backup Camera Auto Dual Zone Climate Control Sys w/Rear Vents 10-Way Power Front Seats Power Tilt-and-Telescopic Steering Column Reclining/Sliding 40/20/40 Split Rear Seat Power Back Door Rear View Mirror - Auto Dimming
Homelink Garage Door Opener SmartAccess Passive Entry System Genuine Wood Interior Trim Multi-Information Display with Lexus Personalized Settings
Trip Computer & Outside Temp Display Tonneau Cover
Old Aug 22, 2023 | 05:33 AM
Clutchless's Avatar
Clutchless
Now you need to look at the rear of the headlight housing to see if it is an HID or not. There are youtube videos that show how to replace the HID bulbs. Study them and see if yours look the same.
Old Aug 22, 2023 | 05:56 AM
RX in NC's Avatar
RX in NC
^^ Thanks for providing that video. Sure hope I can remember it for when I happen to need it for my wife's 2015 RX350.
Old Aug 22, 2023 | 12:07 PM
Clutchless's Avatar
Clutchless
It is not that difficult once you have done it a few times. If your vehicle is over 7 years old it is best to replace both bulbs as they do slowly get dimmer over time. If you do a lot of night driving or have trouble seeing at night it is a good idea to replace both after that amount of time even if they both work. There are some D4S bulbs available that claim to be brighter and with farther vision than the OEM bulbs.
RubyLex
Mar 7, 2023 06:49 PM
Sondoan
NX - 1st Gen (2015-2021)
Nov 7, 2016 11:17 PM
jjboys
CT 200h Model (2011-2017)
Dec 28, 2015 06:12 PM
AK-47
Lighting
Mar 20, 2015 10:38 AM
LexTech305
Nov 20, 2012 04:27 AM
