Steering wheel vibrating when braking at high speed
In my case, excessive lateral runout was the culprit -- the hub/rotor combo was the issue ... a good read:
http://www.procutusa.com/zipfind.aspx or https://www.procutusa.com/FindRotorMatching.aspx
Some of the other threads on here talk about upgrading to better calipers/rotors and I think that is a better long-term fix, but checking the lateral runout was helpful in my situation.
The cause is the uneven transfer of the friction material between the pad & rotor, which cause the brake pedal pulsations. All it takes is just a small amount to feel this thru the pedal. My brother & I found that the gen 2's are underbraked for the weight of this vehicle. I did a cost effective brake upgrade using pads/rotors/calipers from a gen 3. The cost of pads/rotors are pretty much awash price wise. You'd be out w/ a pr of reman gen 3 calipers.>> Direct bolt on. >>>One look at the pads # 1005 (gen2) vs #1325 (gen3) as well as >>single piston calipers vs the gen3 dual piston calipers. Since your there< I'd also add SS brake hoses for a gen3 & flush the old fluid out w/ new dot3. I went w/ the Hawk Talon rotors & performance ceramic pads & Goodridge SS brake hose kit from http://tirerack.com & a pr of reman gen3 calipers from oreilly parts. Just throw your oem calipers into the boxes to get your core $ back vs shipping them back somewhere. btw they do offer two different calipers types basically where the vehicle was manufactured USA (Canada) or Japan, which doesn't matter. I did make a thread 'bout this= "Cost Effective Brake upgrade"
@Felix Are you suggesting to replace both calipers? That means replacing all the pads and rotors as well. Well, I could have the rotors resurfaced. I need to check if the pistons are also OK. If not, a good reason to replace the calipers.
Thanks.
Thanks.
The break down is to upgrading your front brakes for bigger gen3 setup...Bigger rotors, pads that are a 1/3rd bigger & two piston calipers vs the oem single piston calipers= more pad/rotor surface area w/ two caliper pistons vs the single piston. Direct bolt on...The oem gen 2 brakes, I find are to small for the weight of the vehicle= 4200#......
TV (thickness variation) of the rotors. All it takes is a few ten thousands of a inch to show up thru the brake pedal. Uneven transfer layer deposits of pad material on the rotors. I'd also add that the gen 2 brake system is under engineered for the (4200#) weight of this vehicle. One look at the gen 2 pads #1005 vs the gen3 #1324 pads, as well as the gen 2 single piston calipers vs the gen 3 two piston calipers as well as 12.5'' vs 12.9'' rotors. This is a great cost effective brake upgrade....Go to your local auto parts store & ask to see #1005 pads & #1324 pads......as that'd give you a great visual look.....
Paul4949 (09-06-23)
First rule of diagnosing a problem is that ALL parts are suspect. Just because a part is new, almost new or checked by someone else, never skip checking that part. The first thing I would do is have the rotors checked for runout or a light resurfacing done.
I doubt that the calipers are the problem, but if you replace them, that does not require that you to replace the rotors and pads.
There are other Causes, but Warped Rotor(s) are the #1 Cause, and Ceramic Brake Pads make it worse on the earlier RX's because of the composition of the brake pad and the Increased pedal pressure needed to Slow/Stop the car and the relatively Small/Thin rotors on the Early model RX's.
I spent numerous hours in my early tech years troubleshooting a car's problem, and one of the Main Reasons was " that Part is New"!!
Well, It Doesn't Mean a Thing just because it's New!
Hi, As a former Toyota/Lexus Master Tech with 30+ Years experience, it has been my Experience that 85/90% of brake pedal vibration and/or steering wheel vibration while applying the brakes is a Warped Rotor(s).
The Semi-Metallic pads are a little bit noisier, and they dust the the wheels a little bit, but they will Stop Great, and they Won't Warp the Rotors!
There are many Good Semi-Metallic Pads available for your RX, likel Akebono.
A Semi-Metallic pad does Not Require the pedal pressure that a ceramic pad does and the rotor doesn't get nearly as Hot and the rotor doesn't Warp!
On the later model RX's, a Ceramic pad is the Preferred Pad!
My opinion only, but it's worked for many of my customers!
Paul4949 (09-11-23)
IDK if you have a few or a lot of hill's, but what I've find is turning the rotors will do the job/work for awhile......Great idea is to clean up the hub/mounting surface before installing the rotors. Brake pad material has sure changed alot over the years. There are a few brake manufactures that have different ceramic pads w/ varies compressablity. Just to add you'll find changing the brake hoses to SS or even new oem ones as well as flushing out the old brake fluid w/ new dot3 to have less pedal travel. Yes the gen3 upgrade you'll find even less pedal travel & depending on the pads have less pedal travel......
Paul4949 (09-11-23)
Yes I Do.
So you recommend running a semi metallic over a ceramic pad on a 2004 RX330 AWD
Paul4949 (03-26-24)
Warped rotors can occur even with new rotors installed. The main culprit? Techs who do not follow a star (criss cross) pattern when torquing down the lug nuts. Better to torque the lug nuts manually (no impact wrenches) in two or three stages until the final torque spec. Very easy to damage new rotors if you use an impact to tighten lug nuts.
fred9xx (03-27-24)
Always use OEM on Lexus
Hi I worked at Lexus toyota 14 yrs. In my 3 decades of working in foreign vehicles , Lexus and Toyotas do so much better with oem rotors and pads. I got cheap on my 08 rx350 with Napa premium and in 1 and a half yrs had pulsation issues. Then spent the money with oem rotors and pads no issues for 3 yrs now. Also had same problem with my 00 es300. Bought from a private seller they changed out front pad and rotors with cheap Autozone parts had to recharge out with oem rotors and pads. So hopefully you’ve had your issue resolved. Thought I’d give my 2 cents
The inconvenience of a little brake dust and a little more noise, is Far Better than Warped Rotors from using Ceramic Pads on the older RX's.
The Rotors on the older RX's are too small and too thin to handle the Heat caused by Ceramic pads!!
OEM over aftermarket
I have a 2005 RX330 w/AWD and that's what I've been using.
