Need diagram sensor2 bank1 for 2005 RX330
Old Jan 26, 2021 | 12:17 PM
atlantatan's Avatar
atlantatan
Default Need diagram sensor2 bank1 for 2005 RX330
Hi guys, need a little help with a rx330 I have code P0037 bank1 sensor2 I order from Amazon part Denso 234-4509 I search only have rx300 but can't find anything on the rx330. Popping the hood I only see 1 sensor. Can some please let me know where b1s2 is located or a how to? Thanks in advance for any input.
Old Jan 26, 2021 | 12:42 PM
Mesquite77's Avatar
Mesquite77
Sensor 2 is the O2 sensor after the cat attached to the exhaust manifold, Sensor 1 is the AF sensor after the exhaust manifold before the cat, and it is sensor 1 you see when opening the hood.
To see sensor 2, bank 1 (firewall side) look just after the cat that is attached to the exhaust manifold, and you will need to get under the car, and remove a belly pan (if RX330 like RX350) to see it maybe.
On the RX350 at least, it is low enough down (because engine sits angled to the firewall) to be out of the way of the firewall clutter, and should not be hard to replace.
AZGS4
Jan 26, 2021 05:35 PM
tharith
Jul 31, 2015 06:26 AM
winsalem
Feb 17, 2005 02:18 AM
