power window switch
Old Jan 10, 2021 | 06:57 AM
matts6887's Avatar
matts6887
Since you had work done on the car, I would try the initialization process first to reset all the windows just to rule that out and it's easy.
Hopefully others have ideas.
well the work didnt involve taking off any of the battery cables or removing the battery.
Old Jan 10, 2021 | 08:39 AM
matts6887's Avatar
matts6887
Where are these “modules” at and what do they look like?
Old Jan 10, 2021 | 09:39 AM
cdnewton's Avatar
cdnewton
Assuming it is the switch and not a wire or some other issue, remove the existing piece and replace with this (for Japanese VIN) ... ~$70.
https://www.ebay.com/itm/2004-2009-L...YAAOSwq41dw25a
Old Jan 10, 2021 | 10:04 AM
Margate330's Avatar
Margate330
Problem could be the rear switch/module too.
The MPX1 wire at rear door switch/module is expecting a data/command to open window remotely using key or driver door switch.
Because of complexity is only reason suggesting the initializing procedure to rule that out first in case it was lost and visual inspection of plug connections.
PS- switch/ module is all one piece.
Old Jan 10, 2021 | 12:21 PM
matts6887's Avatar
matts6887
Where on the door is this module or switch? I already tried the key and tried to initialize the window and that didn’t do anything either; also the window will go up and down at the switch on the door itself but will not auto up or auto down.
Old Jan 10, 2021 | 12:49 PM
matts6887's Avatar
matts6887
How much is the rear module itself
Old Jan 10, 2021 | 12:57 PM
Margate330's Avatar
Margate330
Pics in this post shows switches on top & computer module on bottom all made as one piece.
Old Jan 10, 2021 | 01:42 PM
matts6887's Avatar
matts6887
I might end up getting this but how hard is it to Get the old
one out and put the new one in? Also; how do I know it’s not a wire(s) somewhere between the module/switch and the window motor to which the wires for the controls run to?(im assuming)? See I just don’t want to end up throwing money at it only to find out it’s a totally different issue somewhere
Old Jan 10, 2021 | 04:52 PM
Margate330's Avatar
Margate330
Hi Matts, Techstream or a high end scanner can be used to see if the rear switch is responding to remote commands for Up & Down.
Pulling out the switch is easy for inspection and replacement.
Front switch at 0.50s in video.
Old Jan 10, 2021 | 05:15 PM
matts6887's Avatar
matts6887
Yea I don’t have the money for a scanner. I might just go to my Indy shop tomorrow and have them see what they can find out
Old Jan 10, 2021 | 06:25 PM
cdnewton's Avatar
cdnewton
That is why I asked in post #3, if the shop diagnosed that the master window switch was bad, so you wouldn't be throwing parts at it without knowing exactly what is wrong.
Old Jan 10, 2021 | 07:04 PM
tomr51's Avatar
tomr51
matts you have stated the rear seats are not used, and also that the window can be controlled from the rear controller.
Why waste time and money on a function that you do not use. (if the rear seat is used, they can operate the window with the rear control)
Old Jan 11, 2021 | 05:31 AM
Margate330's Avatar
Margate330
I stopped by my indy shop and because its lexus; to replace the master switch is like 800 bucks!!!
Highway robbery! IMHO
They swing for the home run $$$ on these parts considering it's only a 10 minute job to pull the switch out.
Old Jan 11, 2021 | 06:48 AM
matts6887's Avatar
matts6887
well i have a appointment for tomorrow afternoon to see what the deal is.
Old Jan 11, 2021 | 06:49 AM
matts6887's Avatar
matts6887
because if i ever do go to do a trade in i want everything that needs to be working in proper order thats why.
