I been searching and having a hard time finding the torque specs for my 2007 RX350 front and rear brakes. This is what I come up with, like to see if you guys can help me verify if this is correct.. thanks guys.
Caliper bolts - Front 79lb and Rear 58lb
Slide pin bolts - Front 25lb and Rear 20lb
According to my 2008 manual (by Toyota):
Caliper bolts - Front 77 lb and Rear 58 lb
Slide pin bolts - Front 25 lb and Rear 32 lb
here are the front and rear pages that shoe the torque specs.
10th Gear
Hi
Can you please tell me what is the torque for front and back sway bar ?
links
links
Originally Posted by DennisMik
According to my 2008 manual (by Toyota):Caliper bolts - Front 77 lb and Rear 58 lb
Unfortunately the service manual does not have a nice drawing of the suspension with torque specs, so I had to cut and paste. Lexus/Toyota calls the sway bar "stabilizer bar"
Front Stabilizer Bar Bracket
Both sides: Torque: 16 N*m (163 kgf*cm, 12 ft.*lbf)
Front Stabilizer Link Assembly
Both sides: Torque: 74 N*m (755 kgf*cm, 55 ft.*lbf)
Rear Stabilizer Bar Bracket
Left side: Torque: 54 N*m (550 kgf*cm, 40 ft.*lbf)
Right side: Torque: 19 N*m (194 kgf*cm, 14 ft.*lbf)
Rear Stabilizer Link Assembly
Both sides: Torque: 39 N*m (400 kgf*cm, 29 ft.*lbf)
