Timing Belt advice
Old Apr 27, 2019 | 03:45 PM
Audiqv8's Avatar
Audiqv8
Originally Posted by quantfutur
They had to call in a Toyota mechanic down the street to help him as he couldn't match up the teeth. Said it passed road test but I drove it for 1/8th mile and the engine and VSC lights came on. Turned back and he had left (Saturday). The owner checked the codes (I also took it to Autozone) and got the P0016 and P0018. Have to bring the car back on Monday or Tuesday.
Does it sound like the teeth are off one? Mechanic thought could be off by millileters if at all he checked and triple checked but why would I be getting these codes on millileters if it's not off one tooth at least?
Also, there is a squeal at low speed or coming out of a parallel park that wasn't there. I pulled into a local garage and the mechanic listened to the noise and said it's the power steering belt; it needs to be adjusted.
Is it possible the power steering belt was removed in this ace job of timing belt replacement? I have read that sometimes power steering pumps are removed on this job but I will expect any adjustment of the belt will be gratis, as will the resolution of the code issues.
As I stated in my earlier post make sure the mechanic is qualified to do the work. There are two marks on the crankshaft, one on the little gear and one on the big gear, you time TDC (top dead center) to the big gear. P0016 and P0018 are stating that the crank and cam are out of sync. The alternator/ac belt along with the ps belt is removed in order to remove the timing covers and to remove the timing belt tensioner. Here is a video on a Toyota Sienna which uses the same engine as the Lexus RX330. The sequel is most likely from the PS belt being put on in the reverse direction if the original belt was used. The mechanic should have marked or noted the direction of the belt travel.
Although the video is from a Sienna 3.3L it is the same engine as the Lexus RX330. This is one of the better videos on changing a timing belt for the 3.3L engi
ne
Old Apr 27, 2019 | 08:36 PM
quantfutur's Avatar
quantfutur
Thank you for the videos and discussion. I will share this with mechanic on Monday. I may to insist that they bring back the Toyota mechanic. Owner was hoping its just some dirt that is producing the two codes and an easy fix. He doesn't know about power steering belt issue yet. I will insist that car be road tested for some miles after the fix, which will need to include an explanation so that I can have some confidence. I really like the mechanic and the shop but he should have said the job is a rarity for him. I would have then gone elsewhere.
Old Jan 19, 2022 | 11:08 PM
bRicardi1's Avatar
bRicardi1
Wink wrong timing marks
ne https://www.youtube.com/watch?v=0rCVDLM2hzE
I'm screwed,I turned the engine, using the wrong crank marks, did I damaged it. After correcting it, the engine will not rev passed 1600rpm.
lou95gts
Jun 26, 2020 04:43 PM
milosk
Oct 17, 2018 05:57 PM
Band
Sep 5, 2014 11:35 PM
05SC430PB
Jun 26, 2013 09:18 AM
lexus114
RX - 1st Gen (1999-2003)
Mar 5, 2008 07:56 AM
