converting Daytime lights to white LEDs
I am thinking to change the Day time running headlight lights (DRL) on my 2007 RX350. I am tired of the yellow look. I want to switch to white/blue LED DRL. I have the HID cool white factory low beam headlights and want a similar look for the DRLs. Does anyone know what number the DRL bulb is?
Also does anyone has good recommendations to cool white DRL bulbs? or manufacturers? and how easy is the installation? Thanks |
Highs beam are bulb type 9005. You will run into an issue though, the DRL will screw with LED's as the DRL's function as the high beam too. DRL uses a PWM (pulse width modulation) to extend the filament bulb life which runs the bulbs at a lower voltage and this doesn't play nice with LEDs, you will have dim and flickering LEDs. If you want to fix this, either have the DRL disabled completely or run big capacitors before the LEDs but this will run the LED's at full voltage and basically be a high beam during the day. I have capacitors on my LED DRL/Highs on my Camry, had to turn the DRLs off as I was blinding drivers. For brands, my personal opinion, just get whatever mid-priced LED bulbs you can find off Amazon, DRL's/high beams don't warrant the need for high end bulbs especially if you're in the city and never use them.
also, at least on my vehicle, the DRL/high beam bulb is on very dim when the regular headlights are on.
Got the MTEC 6500K kit that is both a DRL and High beam with the 9005 bulb. No regrets at all, looks great and the high beam is extremely bright. Also have not noticed any flickering.
9005 led
I got one for sale. Check out my latest post. Awesome DRL but you do lose some high beam compare to oem
since they are LED. If you don’t use high beams at all or very rare they are the best WHITE DRL LED |
Originally Posted by RXGS
(Post 10407536)
Let us know the outcome and take pics. I tried LEDs and couldn't get them to stay on as a drl, only worked as a high beam. So I just picked up Sylvania zxe and called it a day. But still not exactly happy with the look .
Same here, tried different Halogens, as white (or violet as they come) and could not get a good look. I ended up disabling the DRL and instead I installed an LED strip that is on all the time. On daylight it acts as the DRL (it is pretty bright) and at night it adds illumination. And I get to keep my high beam halogen lamps.
Originally Posted by mandyfig
(Post 10415920)
DRLs that are disabled do not affect the rest of the lights.
(Post 10416065)
DRL bulbs using 6 Volts and LED bulbs do not work on this voltage.
(Post 10407536)
So i finally purchased installed 9005 LED bulbs with decoders/Canbus purchased from amazon. However came across a few issues:
1. The LED bulbs did not turn on as DRLs, they only worked as high beams, even though it has a decoder. 2. I tried to put in the original factory 'yellow' bulbs back in , but strangely they also did not work as DRLs, but only came on as High beams. Do you think i might have blown a fuse? If so which one where would it be located? Appreciate any advise to try to get the LEDs to run as both DRL + High beams even if they run constantly as High beams for DRLs |
Your experience is similar to mine. After many, many attempts, I finally gave up and simply installed some Philips 9005 incendescent bulbs from my Volvo 850 that just happen to be slightly less yellow than the Sylvanias that were previously in my RX330.
I tried two LED 9005 bulb pairs, both from CNLM via Amazon, that purportedly work @ 6V. The newer model's page even includes a photo of the LEDs illuminating on 6V from a power regulator. Doesn't matter. They still don't work. Most frustrating was that my initial attempt in May immediately killed DRL functionality in my car entirely, even with the prior incandescent bulbs back in. Ultimately, I had to use the Toyota Techstream software to (1) confirm that DRL was supposed to be on, (2) turn DRL off, and then (3) turn DRL back on. Suddenly, DRL worked again. It was an excruciating level of effort just to get DRL back. Fortunately, my second attempt with allegedly DRL-friendly LED bulbs didn't kill my DRL again. I will learn to love incandescent DRL and High Beams on my 2006. My next RX will be newer and will have a completely different DRL method. |
