RX330 Blowing Hot on Passenger and Cold on Driver
Old 11-13-18, 09:45 AM
mandyfig
mandyfig's Avatar
Default RX330 Blowing Hot on Passenger and Cold on Driver
Out of the blue, when set on HEAT, I get hot air from the Passenger side and Cold on the Driver's side.
Anybody has seen this happen?
I did a quick battery terminal reset and it did not change the hot-cold issue.
TIA for suggestions. It is getting cold and I will freeze my behind if I do not get this resolved.
Could it be the temperature controller (dual temp setting)? The mixing valve?
Old 11-13-18, 02:08 PM
ukrkoz
ukrkoz's Avatar
Simple stuff first. You do have Dual set to hot on your side? Or, turned off completely so both are supposed to be same temp? I know, I know yet... goofy mistakes I have done...
Otherwise, yes. Most likely climate control got monkey brain.
Old 11-14-18, 03:50 AM
mandyfig
mandyfig's Avatar
Yup, had to switch to Dual otherwise I will freeze...and shut off the vent on the DR side. When it rains, that's the issue, I need to turn on the AC to get the fog out...
Old 11-14-18, 03:51 AM
mandyfig
mandyfig's Avatar
I need to do longer battery off to attempt a re-set. Yesterday I did a quick battery terminal un-hook, so quick it did not do anything. This weekend I will do a longer one. With the temps being in the low 40's and damp, it is feeking cold!
Old 11-14-18, 02:13 PM
ukrkoz
ukrkoz's Avatar
I don't like disconnecting batteries. I prefer fuses. Works as well and does not leave behind goof lights flashing. Locate your climate control and whatever else relevant fuses and pull them out.
Old 11-16-18, 04:10 AM
mandyfig
mandyfig's Avatar
I will try that too.
However I started to have this tranny hunting issue (could be related to overfilling the tranny fluid - another story) and I will really like to reset the ECU all together. So that's what I will do 1st.
Old 11-16-18, 10:48 AM
iolmaster
iolmaster's Avatar
Could be the blend door actuator in the heating cooling system. Or even a blocked heater core. Not uncommon.
Old 11-16-18, 01:14 PM
mandyfig
mandyfig's Avatar
I will check around this weekend, I will remove the panels and take a look. There has been a few posts that show the component that could be defective.
Old 11-16-18, 01:18 PM
mandyfig
mandyfig's Avatar
Ok, I forgot to mention that a week ago i ran the RX to warm it up and I ended up letting it run for an hour. The engine bay was hot when I finally turned it off. This No heat situation happened after that incident! The wife was so upset at me. I actually fell asleep and forgot about the car running in the garage. I wanted to bang my head to teh wall.
Old 11-12-19, 06:31 AM
mandyfig
mandyfig's Avatar
It is winter time and I freeze ma *** due to no heat on PASS side. Hence I do not us RX on winter months. But have no choice to use it if we are hauling people and stuff.
daveLL
08-25-20 01:30 PM
Lexterr
11-04-17 11:54 AM
6SOARER
01-18-15 11:48 AM
shytown350
03-07-12 08:21 PM
T8LEX
12-09-10 07:08 AM
Quick Reply: RX330 Blowing Hot on Passenger and Cold on Driver
