2007 Rx 350 suspension problem
Old May 20, 2018 | 11:49 AM
Rx350alex's Avatar
Rx350alex
Default 2007 Rx 350 suspension problem
I have 3 broken suspension sensors on my car. I took them all out. The back of the car is high and the front low. Both lights are on, the afs and the suspension one as well. I just want the car to read that there are no sensors and should go on “broken” mode and level the car on normal as it did before when I had only 2 broken sensors. Is there a way to get this done other than taking the battery out and put it back again? (Already did this) thanks!
Old May 21, 2018 | 11:13 AM
DennisMik's Avatar
DennisMik
It might be that you need to disable the 4th sensor. The height was OK with 2 and now the 3rd bad one creates your problem. But this will not make the warning lights go off. Overall, I think it would be best if you replace the broken sensors.
ciga
Sep 30, 2020 01:49 PM
rcjensen
Nov 5, 2017 07:40 PM
lisa1838
LX - 3rd Gen (2008-2021)
12
Dec 5, 2012 06:32 AM
PatsSoxfan
RX - 3rd Gen (2010-2015)
13
Jul 23, 2009 12:58 PM
