Are there supposed to be slider bushings on rear pins for 2009 RX350?
Old 07-20-17, 06:31 AM
azncapcom
azncapcom's Avatar
Default Are there supposed to be slider bushings on rear pins for 2009 RX350?
I was changing out the rear pads and rotors and lubricating the caliper slide pins and I noticed none of the slide pins had the rubber bushing.
One pin on each side did have the groove on the pin to fit a bushing but neither had it on.
I am curious if there is supposed to be a bushing for the rear or not?
I have heard some cars didn't have the bushing even though the pin had the groove.
Old 07-20-17, 08:51 AM
5W40
5W40's Avatar
I think so as 09 RX350 [JPP] share the same part number with 06 RX330 [JPP]: 47815-48050 , 47814-48050 & 04479-48050
Some photos few years back, sometime the rubber bushing may come off and stay inside when disassembly the caliper.
Old 09-04-17, 06:02 PM
cdonpaul
cdonpaul's Avatar
Default Rear Caliper Slide Pin with Bushing Location
For a 2007 RX 350, does the caliper slide pin with the rubber bushing at the ned go in the top or bottom location?
Manual says bottom, but mine were in the top when disassembled. I took pics. Thanks
Old 09-06-17, 08:46 PM
azncapcom
azncapcom's Avatar
are you referring to the front or rear? For mine, the rears depending on which side, 1 was top, 1 was bottom. I forget if the front side did the same or not.
emLEX
Suspension and Brakes
12
11-06-17 10:57 AM
Bankswood
09-02-14 06:49 PM
StevieA
12-05-12 04:46 PM
Sup2jzgte
05-05-10 04:32 PM
Quick Reply: Are there supposed to be slider bushings on rear pins for 2009 RX350?
