lexus rx 350 heater
Old Apr 4, 2017 | 09:55 AM
stowasser's Avatar
stowasser
Default lexus rx 350 heater
have to put up to 80 for heater to work on my wife car she said that at 70 it use to blow warm
Old Apr 4, 2017 | 07:44 PM
RamAirRckt's Avatar
RamAirRckt
Sounds like the actuator(s) are broken. Mine works, but isn't very good, and I need to replace or repair it too...
Old Apr 4, 2017 | 08:53 PM
Lexuswiz's Avatar
Lexuswiz
Could be a few things:
1. Low coolant or air in system
2. Stuck Thermostat
3. Actuator motor stuck/broken
I would check the coolant first, it's fast and easy to add more and "burp" the system. Next would be to look at the actuator itself, if the motor moves while you adjust the temp, you should be in good shape. If not, this could be a hefty fix as some Toyota/Lexus models do not let you just change the motor. I haven't looked at my 330 yet but on my camry the dash has to come apart for repair of that. I find T-stats issues more common then the actuator.
StevenJett
RX - 3rd Gen (2010-2015)
Dec 7, 2024 02:32 PM
Sparkie350
Dec 30, 2017 11:44 PM
SScharder
RX - 1st Gen (1999-2003)
May 5, 2014 01:02 PM
lostinthew
Jun 25, 2010 11:15 AM
Hamakimon
Dec 3, 2009 10:56 AM
