air suspension issues AGAIN!!!!!
it seems like this a common trend with these cars. I recently bought a 2004 rX330. I didn't know the suspension was bad until the first longer than a test drive trip.
I looked for holes. I set it on high over night and waited to see if it deflated. It is the same height on all sides and doesn't seem to be lagging at all. I had it sit beside another rx330 without air suspension and it looked the same. I don't know what direction to go but I can not take the roller coaster anymore. Compressor still runs and let's down when getting out. Please help. I need all the input I can get. |
Originally Posted by aricks2
(Post 9114999)
Originally Posted by Jgmonkey
(Post 9115007)
I'm sorry I don't understand what the problem seems to be. Just by reading your post everything sounds like it's working fine.
I thought at first that it was just how the air suspension was. After about a week I knew it couldn't be. Everyone that gets in says it's rough and my mechanic said "everything fine but it drives like s***". I feel EVERY bump in the road and then I do the bobble head thing from the aftershock. Ugh it's horrible.
I wonder if there is an issue with pressure regulation somewhere and it's overinflating the airbags. That, or there could be damage to some suspension component.
(Post 9115013)
Yeah, that's what it seems like until you ride and turn into a bobble head. I had an rx300 and my mom has the other rx330 and neither have ever ridden this rough.
I wonder if they wear out over time. Not leak, but get soft. I guess I'm not understanding what's on the inside to keep them from smashing all the way down.
Are the shocks inside the bags?
(Post 9115037)
Maybe dead shocks? Or try and check the suspension links or even the sensors
(Post 9115051)
I would just change the while system out with a full aftermarket bag setup. In fact that's exactly what I did |
(Post 9115053)
Suspension links..... wiki is not telling me well what these are.
(Post 9115056)
These links are hooked up to sensors that tell the ECU when to turn on and off so that you don't make your car too high or too low. I think these are the same links might be within the same system as your headlight links (afs)
(Post 9115061)
What setup did you use? Lexus seems to want both arms and legs for these. The car will still raise and lower fine. If I raise it, it lowers its self to neutral at the 15mph range. Only other weird thing, and maybe it's a seal, sometimes it sounds as if it's passing gas. And it does that on the front right side but only randomly. I didn't think this would cause all 4 to act up. At least I'm assuming that's what's making the noise. But like I said, it holds air fine over night.
For me I'm trying to completely modify my car so that's why I went that route. But in all actuality the factory air system to my understanding is ment for getting in and out of parking structures if need to |
https://cimg2.ibsrv.net/gimg/www.clu...7064dee90e.jpg
(Post 9115066)
I have airrex air struts personally but I think airrunner has a setup aswell
For me I'm trying to completely modify my car so that's why I went that route. But in all actuality the factory air system to my understanding is ment for getting in and out of parking structures if need to Here you go. This is what my car looks like all the way down. Sorry i dont have a pic all the way up. |
