RX 350 limited slipdiff??
Old 03-27-15, 07:48 AM
tizelwazze
tizelwazze's Avatar
Default RX 350 limited slipdiff??
Hi,
I'm about to service the car and got stuck with choosing oil to the trasferebox and diff .
Toyota/Lexus in sweden uses Castrol Syntrax , but i dont know if i have Limited slipdiff or not,,
The oil i'm about to purchase is Castrol Syntrax Limited Slip 75W-140 ,
https://www.oljemagasinet.se/index.p...facturer_id=13
Old 03-27-15, 11:39 AM
lexsc4
lexsc4's Avatar
I used Mobil 1 75W-90 Synthetic Gear Lube on both transfer case and rear diff without issue. It has been almost 5K miles since the fluid change.
08 RX350 AWD
Old 03-27-15, 11:46 AM
robbyk
robbyk's Avatar
08 RX350 AWD
At what mileage or how often am I supposed to change the oil on both the transfer case and rear differential?.
How do I know if i have Limited slip diff or not.
05 RX330 AWD
Old 03-27-15, 04:22 PM
lexsc4
lexsc4's Avatar
My mechanic told me that every 30K mile should be sufficient for the rear differential and transfer case. The front differential, if my memory is right, is the same as the transmission fluid, which get a 30Ku drain and refill every 25-30K miles.
Old 03-27-15, 05:37 PM
tizelwazze
tizelwazze's Avatar
But i have to know if i have LSD,
So i can choose right oil,
every brand has LSD & Non LSD oil
Old 03-28-15, 07:56 AM
robbyk
robbyk's Avatar
I know what rear differential is, what is the transfer case?
Old 03-30-15, 07:55 PM
neelnaik
neelnaik's Avatar
@tizelwazze,
The 2nd generation RX was not available with a limited slip differential. The recommended oil rating is 80W-90 (commonly referred to as 80 90 weight) gear oil for both the transfer case and rear differential. The recommended oil rating and capacities should be in the back of your vehicles Owner's Manual. Should be 1.0 quart each if I remember correctly.
(available online here: https://secure.drivers.lexus.com/lex...nual-search.do)
The recommended interval for changing the transfer case and rear differential oil is 90-100K miles, according to my local dealer. I believe the owner's manual specifics 100,000 miles if I remember correctly. I change mine out at every 30K miles as cheap insurance, so to speak.
The front differential is lubricated with the transmission fluid. The transmission fluid is shared between the transmission and the front differential, so follow the recommended service intervals for the transmission fluid for that.
@robbyk
The transfer case is located between the front and rear differentials. Simply put, it is what splits power between the front and rear.
Old 03-31-15, 03:23 PM
robbyk
robbyk's Avatar
Originally Posted by neelnaik
@tizelwazze,
@robbyk
Awesome, thanks.
I am going to make the time to get under the car to see what tools I need to replace the transfer's case and rear differential's oil as I am pushing 93K miles.
Old 04-01-15, 05:25 AM
tizelwazze
tizelwazze's Avatar
thank you Sir!!
Acrad
GX - 2nd Gen (2010-2023)
356
12-26-23 04:36 PM
MNSC3
05-16-14 02:15 PM
storms71
10-18-12 09:03 PM
hugo2648
RX - 1st Gen (1999-2003)
07-23-07 06:40 AM
Grumpa72
01-30-06 06:32 PM
Quick Reply: RX 350 limited slipdiff??
