Anyone have crank pulley holder I can borrow for TB install?
Old 03-28-14, 02:16 PM
alchemist
alchemist's Avatar
Default Anyone have crank pulley holder I can borrow for TB install?
Need it by next Friday.
I will pay for shipping then send back to you.
Something like this:
Amazon.com: Toyota, Lexus Crankshaft Pulley Holding Tool: Everything Else Amazon.com: Toyota, Lexus Crankshaft Pulley Holding Tool: Everything Else
I am going to try impact gun to remove bolt first, if that doesn't work I will muscle it.
Old 03-28-14, 03:00 PM
RX330inFL
RX330inFL's Avatar
You might also try your local B&M parts store as many have a tool loan program requiring nothing more than a deposit.
Old 03-28-14, 03:26 PM
alchemist
alchemist's Avatar
Thanks.
it is where I will get the pulley puller (Autozone) but they dont have the holder.
Old 03-29-14, 09:22 PM
salimshah
salimshah's Avatar
How about building one.
3" wide iron/steel 2-3ft long
1.5" (for the socket to get through) drill
3/16" drill
2 bolts
Plans are some where in first gen RX.
Salim
Old 03-30-14, 05:48 AM
alchemist
alchemist's Avatar
I will but i couldnt find the link. Any help here?
Also what size are the bolts needed as i may have to buy them even for the autozone pulley puller. I heard that kit may not have the right bolt size.
Thanks
Old 03-30-14, 09:46 AM
RX330inFL
RX330inFL's Avatar
Is this what you are looking for?
https://www.clublexus.com/forums/rx-...ghtmare-2.html
Was right here at 2nd Generation RX.
Old 03-30-14, 06:05 PM
HtownBlue
HtownBlue's Avatar
I used an impact wrench a few times. One time I used a long breaker bar and used the starter to loosen the bolt by quickly turning it over without starting engine. Both methods worked fine for me. You can you tube the breaker bar procedure.
Old 03-30-14, 06:56 PM
alchemist
alchemist's Avatar
And you didnt need holder for this right since the starter is turning the pulley against the breaker bar not vice versa right?
Old 03-30-14, 06:57 PM
alchemist
alchemist's Avatar
Perfect, just what i was looking for thank you!
Old 03-30-14, 09:07 PM
thomas1
thomas1's Avatar
I made one of these and with just a breaker bar was able to remove the crank bolt. I had tried the impact, but it just wasn't making it. with the holder tool it was a snap.
Old 03-30-14, 10:32 PM
alchemist
alchemist's Avatar
Nice. Thanks, good to know
Old 04-06-14, 07:10 PM
satnerd
satnerd's Avatar
I doubt very seriously you gonna get it off with an impact. We tried with a big gun from the local tire shop & a 200 psi compressor & it didn't budge. We ended up making up a holder from a piece of flat stock. Cut a v in it to clear socket & 2 holes for the bolts to screw in to pulley. Used breaker bar then impact to run it out & holder worked as a puller as the bolt came out.
Old 04-06-14, 07:21 PM
alchemist
alchemist's Avatar
Actually the Snap-on MG725 did it no problem:
https://www.clublexus.com/forums/rx-...iy-w-pics.html
Old 04-06-14, 07:22 PM
alchemist
alchemist's Avatar
I had the 3/4 inch impact wrench rated at 1100 ft lbs as backup
jwynn
SC- 1st Gen (1992-2000)
07-24-15 06:30 AM
Lexus082
Performance & Maintenance
05-06-14 01:15 PM
drstrangel
03-21-09 03:04 PM
TMaxxTim
07-12-05 09:46 PM
Quick Reply: Anyone have crank pulley holder I can borrow for TB install?
