New Tires
Old Jul 11, 2013 | 09:32 PM
Tank's Avatar
Tank
Default ...............
Originally Posted by RX330inFL
While the Michelin Latitude may be a very good tire, in the 235/55-18 tire size its load rating is "99" (= 1709 lbs), its speed rating is a "T" (= 118 MPH) and its temperature rating is only a "B".
The original OEM Michelin tires for this +1 size on my RX were rated at "99" load index, "V" speed rating and "A" temperature rating.
With a gross vehicle weight of 5245 lbs minus a curb weight of 4065 lbs you are left with a max payload of only 1180 lbs (numbers are approx.). Put four adults along with a bunch of luggage in the RX and you reach that max value very quick which puts extra stress on your tires.
Now, while I would probably never reach anywhere near those speeds in my RX I would personally prefer a tire with higher specifications for heat dissipation at speed due to the road temperatures I am apt to drive on during the summer and a equal to or higher load rating for those times when I am fully loaded and running heavy on a long trip. Getting tires which are over specified for my needs gives me some peace of mind.
Of course, this is just one person's opinion.
Thats kool thanks for that info, it helps. very very rarely will there be 4 adults in the wife's RX, and I'm in the North East so temp is not a huge factor. got em for a decent price. just tried to look out for the Wife and get her some decent tires, plus my kiddie rides with her too so you know how that goes. me I could care less about what I ride on, that is.. untill I get into an accident..:doh
Old Jul 12, 2013 | 12:09 AM
RX330inFL's Avatar
RX330inFL
I think that just proves that each person's needs are different. In your case you probably made a wise investment. While you may have gotten a good price, you did not cheap out (Michelin does make a quality tire as opposed to say going with Nankang) and new decent tires are usually much better even high quality well used ones in many regards.
BTW, I grew up in PA and it does get quite hot up there in the NE some summers. Can get hotter there than what I see here in my part of FL. Being close to the water, this area has not seen a 100°F temp ever that I am aware though we get a lot of high 90's. Fortunately for you that it doesn't go on for month after month. Still, the asphalt and concrete roads most everywhere do get extremely hot which is transmitted back to the tires. The tires have their own load stresses which also generate heat. Just a matter of not over stressing the tires and not overloading the vehicle, keeping the tire pressures in the proper range, and perform visual inspections on a regular basis. Do not wait until you need an oil change to have your tires inspected. It is something you can do yourself in a few minutes. When we hear about tire failure accidents on the news there is a high probability that one or more of the above rules was broken.
Old Aug 15, 2013 | 07:44 AM
Castle4U's Avatar
Castle4U
Question
Originally Posted by alchemist
I have this exact size in pirelli scorpions and love them
Alchemist, what made you choose these? I've been looking at these and the Cooper CS4 Touring for my 2005 RX330 AWD.
WhiteES350
Aug 7, 2016 03:59 AM
j stuff
Wheels and Tires Classifieds
May 2, 2011 11:56 PM
Lexwang07
Wheels, Tires & Brakes Forum
Oct 29, 2008 07:18 AM
jeffyjeff
May 24, 2008 08:32 AM
