Tail shaft bearing question
Hi guys,
Just need some advice on center my tail shaft bearing.
Recently i have heard what sounds like a wheel bearing noise seems worst around 40kph, when i took a look under the car it looks that the center tail shaft bearing has been hit and pushed back from the base of it so the bottom of the bearing carrier is pointing a bit to the rear of the car. In every other mount i have seen they sit to a 90 degree angle to the base of the car no angle.
So can anyone confirm that when the bearing ismounted it should be straight or is it in fact on an angle.
It just doesnt look right but i am not sure how the are mounted on the RX330's
Thanks
Thanks
