replace cv joint?
Old May 17, 2012 | 09:42 AM
bagsbie's Avatar
bagsbie
Now, you, guys, getting me paranoid :-) I feel like I need to get in there and check it asap. The only thing that calms me down is the fact that I do not hear any noises turning the steering wheel, the steering wheel is straight. I can also pop the cover and check the steering fluid level to tell me if there's, in fact, a leak in the steering rack. I shall provide the findings here.
Old Jun 7, 2012 | 01:19 PM
sweet100's Avatar
sweet100
Just feel obligated to update it.
A local shop confirmed that my steering rack has slight leak, and they suggest to leave it as is because a replacement costs around $1.5K
I hope it becomes severe sooner, it seems to be fun project.
Old Jun 7, 2012 | 07:52 PM
HtownBlue's Avatar
HtownBlue
I've done a rack in a first Gen Lexus and it was NOT a hard job other than lining up the wheel linkage and mailing sure you transfer the tie rod ends correctly. On my current one, the set up looks almost the same. It won't cost you 1.5 K if you DYI.
Old Jun 9, 2012 | 09:13 PM
sweet100's Avatar
sweet100
Thanks a lot for this info, HtownBlue!
I am thinking about to DIY. Actually I checked the rack today during my first DIY oil change. Your info will definitely make me more confident.
I will put an update here if I decide to start this project..
Old Jan 3, 2021 | 11:04 AM
Reynold's Avatar
Reynold
Default Cv axle
Why is the cv axle outer end so easy to remove ? Is something wrong here ?
newbaby
RX - 1st Gen (1999-2003)
24
May 7, 2015 07:48 PM
genin9
12
Apr 21, 2015 09:16 AM
joeyfett
Aug 19, 2013 11:28 PM
aboss3
Apr 24, 2009 08:54 AM
lexudv
Nov 30, 2006 12:09 PM
